Milling around with bits
Home Forums Workshop Tools and Tooling Milling around with bits
  • #540243
    Tony Pratt 1
      @tonypratt1
      Posted by Stuart Munro 1 on 17/04/2021 16:54:23:
      Tony,
      Sounds like your skill level is a different order to mine, as an accountant I could deflect numbers anyway you wish (but of course didn't) but deflecting a cutter sounds beyond me.
      Stuart
      yes, sorry for being too technical, all will become clear as you progress in your machining journey, as a general rule say for milling use the shortest sharp cutter you can & only use long series cutters if you have to. Loads of online advice will come your way but yes get hands on experience with a decent machinist if you can. Where are you located?
      Tony
      Anonymous
        Posted by Tony Pratt 1 on 17/04/2021 12:59:33:
        Don't want to get in a 'pi****g' contest………………………
        Probably wise, as those types of contest usually end up with someone getting wet shoes. smile
        #540271
        Dave Halford
          @davehalford22513
          Posted by Andrew Johnston on 17/04/2021 20:36:48:
          But only the bloke next to you.angel
          #540287
          Stuart Munro 1
            @stuartmunro1
            ……… but yes get hands on experience with a decent machinist if you can. Where are you located?
            Tony
            Tony,
            Essex – some good sources of 'hands on' advice once covid restrictions allow. Till then fun learning.
            Stuart
