I bought a new Warco HV mill and I love it to bits, lots of bits, it is all in pieces but slowly coming back together.
It came with two horizontal spindles, 22mm and 27mm.
The 27mm has a keyway while the 22mm has none.
Is that normal? I have no experience.
I notice that gear cutter bores seem to depend on the Modulus. At M2.75 they make the leap from 22 to 27mm bore. I wondered if perhaps the smaller sizes need less torque? Seems unlikely.
Perhaps you are expected to cut your own choice of keyway. This could be catch 22 if all the milling cutters that might cut the keyway are bored 22 because they are considered pathetically small out there in the real world
RDG tools have a 1" INT50 spindle that would fit and lots of DP size cutters to go on it. Unfortunately, they forget to say if it has a keyway and I have become suspicious. Also, does INT50 imply it wants a 40mm support bushing at t'other end?
Too many questions
