Posted by John Haine on 27/03/2021 16:00:08:
Also depends on the aluminium. Some machine very nicely, but common aluminium sheet can be a pig, very sticky and sticks to the cutters.
+1!!!
Pure Aluminium is horrible to machine, gooey, sticky, yuk. Other alloys are made to bend or extrude, so DIY store metal, sheet and scrap window frames are best avoided too, as are those intended for electrical work (bus-bars), for welding, or their thermal and anti-corrosion properties. As more aluminium alloys don't machine well than do, it's best to buy the right thing than to muck about with an unknown alloy.
UK metal supermarkets publish this guide, note only one of the machinable candidates is unambiguously 'Excellent', and there are dozens of Aluminium Alloys that aren't rated at all:
Other alloys can be machined, it's just that they are more-or-less difficult, some much worse than others. Having suffered by trying to learn on a scrap box full of unfriendly metals myself, I recommend beginners start with metal designed to be machined, only moving on to the nasties once one knows what to expect of a decent metal.
Same problem applies to other alloys: steel, brass, and bronze also come in varieties that machine well, are truly horrible, or in between. It pays to buy metal that's meant to be machined so the material can be eliminated as the problem when a job doesn't go well. Look for 'free-cutting' or 'good machinability' in the specification.
