milling Acrylic
milling Acrylic
Home Forums Materials milling Acrylic
  • #484895
    Another JohnS
      @anotherjohns
      Hi all; was given a task to mill a pocket and outline in a bit of 3mm Acrylic.
      The searching I did here mentions turning, on-line it's with high speed spindles.
      What have YOU done with a slowish (say, max 5,000rpm) spindle on either a manual or CNC mill? Say, 3mm or 4mm 2 flute cutter.
      I expect to hold this piece down with double sided tape, hopefully I can get it off of the carrier again. 😐
      Advice more than welcome. Thanks – JohnS.
      Another JohnS
        @anotherjohns
        #484905
        Tony Pratt 1
          @tonypratt1
          If you go too fast the plastic will melt.
          Tony
          #484908
          Former Member
            @formermember32069
            #484918
            Adam Mara
              @adammara
              I use Carbide Create on a 3018 CNC router, usually with a 3mm or 1.5mm bit. Speed is set at around 4000rpm, depth per pass 0.5mm, feed rate 150mm and plunge of 100mm. Not fast, but works for me!
              #484924
              FLguy
                @flguy
                At the medical company I worked for we used lots of WD-40; HSS tool bit with approx. .015 radii at it's tip and spindle speeds about 600 to 650 RPM. Slow feed. Hardly ever a need to polish afterwards.
                #484927
                Kevin Hodgkins
                  @kevinhodgkins45489
                  I cut and engrave cast acrylic (perspex) with my cnc router, and find it a fairly easy material to work with.
                  I usually cut a high spindle speed ( 20,000 rpm,1200mm/min, 1mm DOC with 1/8" cutters ) but that is mainly for chip clearance. I've found lower speeds cut fine, but chips accumulate in the cuts.
                  As an experiment I took an off-cut and tried it in my manual mill at 2000 rpm this afternoon and quite happily machined some pockets and slots with no drama.
                  I tried machining extruded acrylic once, I'll not be trying again.
                  #484942
                  Georgineer
                    @georgineer
                    Posted by Barrie Lever on 10/07/2020 14:40:18:
                    There are two types of acrylic sheet, extruded and cast, the extruded material clogs up/melts around the cutter very easy so keep temperatures down.
                    B.
                    What he said. The extruded stuff goos up like chewing gum, puddles the cut, and sets rock hard when you stop. The cast stuff machines beautifully and smells nice while you're doing it. I've never used coolant, but I keep the depth of cut down and the feed rate up to get the heat away quickly. Talking two-flute end mills up to about 4 mm diameter; no idea off the top of my head what speeds and feeds I used.
                    George B.
                    #485442
                    Another JohnS
                      @anotherjohns
                      Many thanks – the support and guidance was appreciated.
                      The Acrylic faceplate machined with absolutely no issues, and results delivered to owner. (doing this for a friend of a friend, he's a radio nut, and had ONE piece of Acrylic of the correct size – no screw-ups allowed.
                      I decided to mill on my manual mill – Centec 2B, the part barely fit with maybe 5mm extra Y travel, but fit it did. On the Centec, I could have my nose down close, and adjust the feed as appropriate; next time I'll know better how to do this on CNC.
                      JohnS.
                    Home Forums Materials Topics
