Typical power requirements (in Watts per second) needed to remove a cubic millimetre of metal are about:
- Aluminium 0.4 – 1
- Cast Iron 1.1 – 5.4
- Brass and Bronze 1.4 – 3.2
- Magnesium Alloys 0.3 – 0.6
- Stainless Steel 2 – 5
- Steel 2 – 9
Note the power figures depend on the alloy being cut. In the case of steel, 2 would be right for mild steel, but a lot more oomph is needed to cut one of the hard tough alloys.
Assuming Sean wants to cut a 130 x 20 x 15 slot in mild-steel. That's 39000 cubic millimetres of steel. At 2Ws per cubic millimetre, the electricity bill will be about 79000W seconds. From that you can guesstimate the minimum time would it take a particular motor to cut the slot.
- 3000W would take 26 seconds
- 2000W – 39 seconds
- 1000W – 78 seconds
- 750W – 104 seconds
- 500W – 156 seconds
- 375W – 208 seconds
The time estimates assume that feed-rate and depth of cut don't matter. They do! For mild steel using carbide, the depth of cut should be in the range 0.15 to 7.6mm with cutting rate between 60 and 135 metres per minute. Even on a big machine the maximum depth of cut suggests a minimum of two passes.
It's not the law though, industrial cutting rates are carefully calculated to minimise cost by balancing of power, machine capability, tool life, and production time. Big machines can and do take deeper cuts. Not so clever in a home workshop I think where our machines are likely to be relatively small, not very rigid, or worn. Better to proceed by feel and experience than calculation.
How powerful is the motor on Sean's Centec? That plus the machine's lack of rigidity will determine how many cuts it will take him to do the job.
Edited By SillyOldDuffer on 29/11/2017 11:33:36
