Mill upgrade Axminster/ Sieg SX2?
Home Forums Manual machine tools Mill upgrade Axminster/ Sieg SX2?
Viewing 2 posts - 1 through 2 (of 2 total)
  • #703500
    jon hill 3
      @jonhill3
      Im concidering and upgrade from my small Proxxon FF400 mill to another desktop machine. This time slightly larger and more capable ie removable drawbar with a wide range of easily available collets and stiffer collum.
      I think I can just about fit an Axminster or Sieg SX2, Im not fixated on this brand or badge name but open to other suggestions. If the machine could take threaded endmills / slot drill all the better.
        Just about any mill with a MT or R8 taper will take screwed shank cutters with a suitable holder. However a more useful, cost effective and versatile system would be to get an ER collet holder and build up a range of collets. These will hold screwed, plain and Weldon shank cutters as well as many other things like drill bits, reamers, etc. Screwed shank cutters are becoming less common, take a look at the lines of Dormer and maybe only 1% of their range now has screwed shanks.
        Of the two you mention the ARC SX2PG is the more recent model wth the twin gas struts so should be better to use.
