Posted by Lee Jones 6 on 07/12/2020 16:42:51:
Posted by Pete. on 07/12/2020 15:55:04:
Surely the first thing to do, is dismantle it, take the column from the base and have a look, there could have been some machining chips on the base that got stuck between the two parts on assembly, or rough machining that could possibly just need a light stone over to correct.
Worst case, I'd go with scraping to correct if needed, it's a slow process that removes small amounts of material.
I'd have thought referencing the sole of the column to check for flatness would be a good idea, it might be a high spot that needs knocking off to bring it right.
I wouldn't go running a flycutter over your table personally.
I think the flycutter comment was for someone else.
Popping the column off and scraping would be no mean feat on a 400kg machine.
I would have to acquire lifting equipment from somewhere and learn how to scrape (it is on the list!).
The thought of doing so for the first time on my milling machine does leave me feeling a little nervous.
And scraping is not the appropriate method for removing the 0.75mm the base is out by. It's a finishing process, and an advanced skill level that takes a long time to learn correctly. Base would need to be machined to remove that much metal sensibly.
And you are right about not flycutting the top of the table. That would only take a cut parallel to the existing surface so no gain. It is the relationship between the dovetail ways on the vertical column and the horizontal ways on the machine base that the table slides on that is critical.
Of course, we are assuming that the top surface of the table has been machined parallel to the table's lower slideway surfaces at the factory. Perhaps a risky assumption on cheap Chinese hobby machines. I suppose you could check that by holding your dial gauge in the spindle as in your video but with the plunger reading off the surface of the table. Then run the table full length back and forth along the X axis. It should give 0 variation over the full length, or a few hundredths of a mm at most. Then do the same for the Y axis, maybe with a ground plate or parallel laid flat on the table to bridge the T slots. Any variation on the dial gauge indicates the top surface of the table is not parallel to the way surfaces on the bottom of the table.
The other assumption, as someone pointed out above already, is that the spindle axis is parallel in both planes to the quill axis and thus the quill movement. Hard to imagine it being half a millimetre out though. You could possibly check that by tramming the mill as you have done, which sets the spindle axis square to the top surface of the table. Then maybe use a square to eyeball that the extended quill is also square to the table top in both x and y planes. Or with your dial gauge mounted in the spindle, run it up and down the square as you did in the video, but by extending and withdrawing the spindle, not moving the whole head. You should get a 0-0 reading or within a few hundredths mm if the spindle and quill axes are in line.
