I had to get a Warco VMC machine (same as the 626) from my garage door to my workshop via a step up of about 5" height. Total distance about 25 feet. First beware the weights given for the machines! The Warco website says the machine is 415Kg – I believe this is the total crated weight. The Grizzly 626 (USA clone with an excellent manual HERE says 800lb or 363Kg and the label attached to my Warco machine itself gives a weight of 380Kg. The Chester website gives a weight of 320Kg for their 626.
If you have a step to get over as I did then make yourself two ramps – timber will do but they must be sturdy – these will allow you to get up and down the step. You will also need an engine crane of at least 1 ton capacity (2 tons would be much better but I already had the 1 ton crane) – Just be aware the machine exceeds the safe load for a 1 ton crane at full jib extension),
A flat "trolley" about 2ft square with four heavy duty castors for wheeling bits around and uip and down the ramps if you use them (you can make this yourself – I used a frame of 4"x2" timber and a top of a double layer of 20mm OSB, all firmly screwed and glued together). Several large blocks of timber (about 4"x8" approx. 18" long. A garden center sleeper does very well for this but you will have to cut it up!). A second person is also very useful, even if they don't do any lifting they can hand you things and generally help out.
I suggest taking the machine apart to move it. The head and motor should come off as one unit – you will have to undo the wiring at some point to separate them. The table will also come off (take the handles/leadscrews off first). The main machine body should also separate from the base.
Take your time and plan each move you make – these are very heavy lumps of metal you are dealing with. Needless to say a pair of proper steel toecapped shoes or boots are essential.
Hope this helps – if you are not used to moving heavy machinery then do take care!!
Edited By Bizibilder on 28/09/2022 11:49:06
