I have now removed the cover from the electrical box , temporarily removed the on/off switch and reversed the motor wires and the motor runs quite happily backwards.
the motor wires are quite thin so there can't be that much current.
incidentally, I also turned the switch 90 degrees so off is up and on is down rather than side to side.
where the hell did they get that idea from?
all I have to do now is find somewhere to fit the switch.
I may even try replacing the current switch ( no pun intended) with a centre off type, only thing is, there's another wire on the centre row and I don't yet know what that does.
Roy.
