I wouldn't agree with Ian's explanation of stepper motor operation. Like any synchronous machine, the torque generated is proportional to the angular difference between the rotor and the magnetic field. When you step the drive, the field rotates 1/200 of a turn ie 1.8 degrees. If there is no resistance, the rotor will follow the full angle. If there is no movement, the rotor will generate a significant torque, hopefully somewhere close to the alleged "stall torque". Sounds as if you simply don't have enough torque.
Microsteps increase the number of steps but (if driven by a half decent driver) don't significantly decrease (or increase) the torque the motor can generate, despite a lot of misinformation to the contrary.
Although it isn't usually obvious, the speed-torque characteristic of most steppers looks rather like a constant power curve, so changing ratio from direct drive won't necessarily change the maximum speed you could drive the leadscrew at. Indeed, by gearing the motor down by 2 or 3 to 1, you would be able to increase the stall torque at the leadscrew and probably still get the same feed rate under load. As Andrew says, you are probably suffering from static friction (stiction?). This is probably one of the main reasons people change to ballscrews, apart from the backlash improvement.
Anyway, in terms of solutions, 2 come to mind:
- If you are intent on driving the knee up and down, you can reduce the load on the Z leadscrew by fitting one or more gas struts (springs) underneath to offset the weight of the knee assembly. You could get an adjustable gas spring if you wanted to play with the spring rate. This seems to be a common technique. Certainly neater than hanging a massive counterweight out the back of the machine. You probably need to leave a bit of weight on to preload the leadscrew and reduce backlash.
- The other solution would be to drive the quill rather than the knee. That's what I've done on my Bridgeport clone (see my albums under "Z-axis drive" or similar) and is much more commonplace with knee mills. Admittedly it limits the travel to 4-5" or so but if you need more, you can always move the knee up or down during the machining process.
Murray
Edited By Muzzer on 05/09/2014 17:28:25
