Hello and thank you in advance for any advice,
I’m an absolute complete novice, so looking for some help here. I’m a piano tuner by trade, so we are normally dealing with woodwork. However, there was a futuristic Dutch company in Ireland in the 1960s called Rippen that made instruments from plastic, steel, and aluminium (and wood where it absolutely mattered). I’ve decided to take on finding new parts that are no longer available (as have a few others over the years), and I’m having trouble with mild steel spring retainer clips (or steel blades) pictured below (from a website of a French engineer that looked at this piano in 2015)
https://alainfelixdenis.wordpress.com/wp-content/uploads/2015/08/piano-lindner-036.jpg
On the picture left is a pile of plastic parts, but on the picture right are the black steel retainer clips with u shaped slots stamped into them (and function similarly to how car radio chassis used be held in place). How or where could I have these made? The retainer clip holds together a plastic pivot support compression clamp (which I’ve had reprinted for me), and an insert which slots into the piano key, and keeps them a specific distance apart if you follow the pictures on link below:
https://alainfelixdenis.wordpress.com/2015/08/10/piano-lindner-remise-en-tat-partie-12/
If someone could easily manufacture them I could happily order 100 or more, price depending of course!! Or tell me where to go look.
Metalwork Home tools are a vice, hacksaw, files, grinder and drill press, so I’m not kitted out for this!
Really really appreciate your taking the time to look through this – thank you very much!
Michael
http://www.laffanpiano.ie
