Posted by Clive Foster on 25/08/2020 12:34:13:
Getting to the point where you need to … use the proper modern designations rather than EN equivalents if you need to be certain that what you get is exactly what you want…
What cured me of EN number substitutes was 4 full lengths of "what we give you as EN 3B" that were all clearly different…
British machinists have often caused themselves grief by refusing to move with the times! Metrication is one example and EN numbers are another.
Problem with buying steels as specified in BS970:1955 is that no one makes them because the system was replaced in 1970. Anyone buying EN3B today will always be given a substitute. And which substitute is in the lap of the gods because the whole system is confused. As my local supplier's customers all ask for steel by obsolete EN numbers, he orders the same from the wholesaler, and the fiction goes a long way up the supply chain. I blame experienced oldsters for blocking progress. Young chaps burbling nonsense about BS970:1970 were soon sorted out. The old ways are the best…
However, a back-office purchaser eventually breaks the fantasy by ordering a real world steel to meet these sloppy orders. Structural steels in the EN3B class aren't challenging, so he'll probably buy whatever is cheapest at the time. Could be from anywhere – European, Indian, American, Russian, Japan, or China etc. As these guys make at least 18 different steels similar to EN3B, who knows what will end up in your workshop!
For most structural purposes the difference between EN3B-like steels like 080M15, 080A15 and SAE1018 probably doesn't matter. Machining them is a different story.
Given tradition has successfully maintained obsolete EN numbers 50 years past their use by date, I'm not sure there's a cure other than asking for a certificate. Nonetheless I've done OK ordering EN1A and EN1A-Pb because the modern equivalents are also formulated to improve machinability. Otherwise buying metal I always check what's said in the spec about machinability and avoid anything described as poor or average.
