mild steel/aluminium suppliers in uk
Home Forums General Questions mild steel/aluminium suppliers in uk
  • #782719
    aytact
      @aytact
      Hi,
      I want to buy mild steel and aluminium as rods and box sections as bulk order.
      Which suppliers are you using? Currently I am using metals4u for small pieces. But for bulk orders they are getting a bit expensive.
      Thank you so much
      Diogenes
        @diogenes
        Does ‘bulk’ mean a ‘big’ courier order? or 6m lengths on a flatbed?
        What region do you live in – obviously if you can collect an order it will save you carriage and handling..?
        #782721
        Speedy Builder5
          @speedybuilder5
          You might do well to look at the posting “Metal Stock” 9 posts down the page on this forum ??
          Bob
          #782726
            If in the South East you might try Parker Steel for the steel rod and section. Quick look at 12mm 230M07 and they are about 20% the cost of M-Machine but that is for full 3m+ lengths.
            However you do really need to order in “bulk” as their own transport cost on top will make it expensive if you only buy one or two lengths. Orders over £500 are free delivery but under are £50 Plus VAT.
            You will also need to be able to get a big lorry to your property and be there to unload the bundle.
            #782740
              I mostly buy from a local emporium because they’re handy.  Last month, feeling better, I stocked up on Aluminium and Brass rod, and didn’t get much for £200.    I saved money by collecting, but had the metal cut to fit in my car, and they also wrapped it in tissue so as not to besmirch my upholstery!  Extra work, retail prices, plus VAT.
              By my standards £200 is a bulk buy, but not to this business.   Whilst waiting another customer arrived with a 3 ton flat bed on to which they loaded enough steel plate and rod to sag the suspension – at least a couple of tons, all uncut, no wrapping.   Much cheaper buying by the ton, more the better, but I have nowhere to store that much metal and would never use all of it!
              If buying in professional quantities is an option, consider registering as a business and negotiating.   Might be possible to avoid retail prices, but don’t dodge VAT!  (If you can’t do the time, don’t do the crime…)
              I haven’t found a cheap way of buying metal, only ways of slightly reducing the pain – shopping around etc. but these days I don’t bother.   The quantities I use are too small.
              noel shelley
                @noelshelley55608
                For Aluminium Aalco- a company with many depots. For steel look for steel stockholders there will be several in your area. You imply industrial quantities ? or are you a BIG model maker ? where abouts are you ? Noel.
                #782761
                aytact
                  @aytact
                  Thank you so much for responses. Our warehouse is around Northampton, I am thinking to buy in 2 – 2.4 m lengths to make it fit into our van. We are VAT registered. Stocking is not an issue, but really I do not want to hire a lorry to carry. We have all the relevant machines to process. (I have tried to answer all posts at once) Thank you for your comments.
                  #782766
                    Well there is a problem from the start 2-2.4m is not a multiple of the typical 3 -3.6m stock lengths, not so bad if you can get the sizes you want in 6m lengths. Are you also purchasing the remaining 1 to 0.6m lengths that the stockholder will more than likely be charging you for as well as a cutting charge?
                    I don’t know what your hourly labour rate plus fuel works out at when collecting but I find in most cases I can earn more in the time it would take me to go and pick materials up than it does to have them delivered. May be different if you have a driver on minimum wage and an electric van.
                    #782781
                    noel shelley
                      @noelshelley55608
                      ASD Metal Services are, or were at Daventry. Buy a cordless 4.5″ grinder and fit a 1 or 1.5mm cutting disc and cut to size at the Kerb, but mind the sparks and paintwork.  Noel.
                      #782785
                      Julie Ann
                        @julieann
                        Jason is correct, there is no point in buying less than the standard lengths for small section mild and black steel as you will be charged the full amount anyway. It is not economical for the supplier to keep offcuts of relatively low cost material in the hope that somebody might want it later. For a small charge you can get standard lengths cut into halves or thirds to help with handling. Parkersteel assume that you have appropriate handling capability, such as a forklift, on site.
                        For aluminium alloys, in commercial quantities, I used Metalfast, now part of ThyssenKrupp:
                        https://www.thyssenkrupp-materials.co.uk/
                        They used to have an outlet in Huntingdon where I could collect. Once they moved to Milton Keynes it was quicker, and cheaper, to have items delivered.
                        Julie
                        #782795
                        aytact
                          @aytact
                          Thank you for responses. I was thinking as you said, cutting to pieces, at the end I will buy full length, but only they needs to be fit into van to reduce cost. Actually, our company is family company and we are working from 8AM to 10 PM every day. And lowering the costs are more important.
                          #782806
                          Chris Gunn
                            @chrisgunn36534
                            aytact, when I was working, i used for steel in Northampton A H Allen, on Brackmills, also Parker steel, who delivered every week, Corby Steel stockists is now Optima, Non ferrous ASC but just looked for them, and now closed by the look of it, but a base in Lincoln.
                            Chris Gunn
                            #782829
                            Mark Rand
                              @markrand96270
                              If the mileage works for you, pick up the ally from Droitwich Aluminium, then stop off at  Barrett Steel in Rugby?
                              #782850
                              Chris Gunn
                                @chrisgunn36534
                                Mark has just reminded me that AH Allen is now owned by Barrett steel.
                                #782867
                                Mark Rand
                                  @markrand96270
                                  And Macready’s, Acentia, (think there was someone else in the long dreary chain of takeovers as well, just of the local steel stockholders)
                                  #782875
                                  Stuart Smith 5
                                    @stuartsmith5
                                    I have used Simmal for aluminium.
                                    https://simmal.com/
                                    They sell usually in 4 metre lengths, but will sell whatever length you want at a pro rate price plus about £5.50.
                                    The delivery charge is a fixed £24.50 so you would need to order a reasonable amount for it to be worth it.
                                    They are local to me (near Preston), so I order online and then pick up myself.
                                    Stuart
