Might prove useful one day
Home Forums Hints And Tips for model engineers Might prove useful one day
  • #98522
    Ian P
      @ianp
      Some time ago when making some parts out of 316 stainless steel, l broke the tip off a 3/16" diameter centre drill (Slocumb bit). The broken bit was jammed in the bottom of the cone and as the part had already had a lot of machining time spent on it I was keen to reclaim it.
      The method I used was very simple and did not even require me to take the job out of the chuck.
      Using one of the thin abrasive disks in a Dremel type tool I ground a clearance slot (same width as broken tip) across the diameter the into the broken end of the centre drill leaving the conical cutting edges untouched.
      I then used the same cutter to cut a bit deeper into the material until the broken tip had no metal l left around it (it fell out by itself).
      Not an earth shattering revelation but it might prove useful one day.
      Ian
      Ian P
        @ianp
        #98528
        Sub Mandrel
          @submandrel
          Neat! Obvious when explained, but I would never have thought of it.
          Thanks Ian,
          Boiler Bri
            @boilerbri
            It's really annoying when that happens. Usually just as you mention – when you have nearly finished the part. I made my axles for the Sweetpea i am building last Sunday. On the last cut i nudged the cross slide handle and took a great big cut out of one of the bearing surfaces. Luckily i had another piece of steel so i made another. Strange, when you remake a part it never seem to take as long!
            Nice tip.
            Bri
            #98538
            Ian P
              @ianp
              Bri
              That has given me a eureka moment.
              Make the second part first, it will speed the whole job up!
              Ian
              #98564
              john kennedy 1
                @johnkennedy1
                Did the same thing last night doing my Firefly carbs (making 2 engines) I took the centre drill out and ground it off at 45 deg,redrilled and knocked the cone off with a centre punch. Not my idea,read it on here somewhere.
                #98578
                Boiler Bri
                  @boilerbri
                  lol Ian
