I have some real consumption figures now. I tend to press on and don't hang around but do generally come close to obeying speed limits.
Worst maybe 1/2 mile there and back from cold 18mpg.
It was raining and didn't want to get wet going to the local shops.
Parcel to the post office from cold. Cica 2miles each way. 25 going and 34 coming back, as it had warmed up a bit I suspect.
25 miles, motor way mostly with a 50 limit for 10 or so miles and around 12 miles of fairly clear A road. 52mpg.
Normal motor way driving 45 mpg.
Pembrokeshire narrow twisty hilly B roads usually 10 mile or so trips 45 mpg from cold. The gear ratio's are unusual for me. Probably done because of the high towing limit. There is a change gear now indicator that works pretty well really. If I disregarded it and drove hard that dropped to 38. It's actually an aid to getting used to the gear ratios and runs a little differently when the engine is cold. There is no temperature gauge just a light. Blue when cold and I expect red if over heated.
The A40 from Haverford West to the M50 is a very varied road. 52mpg even in a hurry. The M50 and M5 after that dropped it to 48. Speed in the outer lane of the M5 are always mmm "highish."
It keeps several tallies of mpg. Current trip since the engine was started gtill it's turned off. Last time the tank was topped up and also the odo based one. I'm assuming they are accurate but the trip to Pembrokeshire definitely used less diesel than the X-Type. Noticeably so. Much better consumption in the lanes in particular and on other parts of the trip.
The change gear thingy is interesting. While overtaking I noticed it didn't say change up when it usually would but did eventually as the revs went up. I also have the impression that it allows more revs at lower throttle setting before the blue light goes out and then changes. Maybe to warm the engine up more quickly. It has the usual problem that it doesn't know that it's about to go up a hill and does like to keep the revs down. I've not really noticed any turbo lag yet. I suspect it uses pretty sophisticated engine management.
Handling I suspect is Wrx like. Likes been driven hard but it really is best to get used to the car before even thinking about that aspect. Cornered easily I can feel how the rear end is tracking. A bit of gas and it feels a lot lot better. Jason probably knows what I mean. At cornering speeds that many wouldn't use a wrx feels like it's on rails especially when there is some power going down. Foresters may be similar.
I might have to continue fitting Yokoharma tyres. Their 4×4 tyres were cheap and brilliant but I suspect that they aren't cheap any more.
Edited By Ajohnw on 30/07/2016 21:07:06
