Posted by Speedy Builder5 on 30/05/2015 12:02:38:
Having said that , I think it is a very expensive way of achieving a brazed joint for MEs as others have said already.
BobH
Very true.
Where it comes into it's own is on MODERN car body work where the modern metal panels are Boron Steel which cracks when you weld it and also looses it's high tensile strength.
Basically is a process that is led by the insurance companies, quite a niche market as regards a process.
Now TiG brazing of steel and cast iron is perfectly good enough and cheap enough using more or less standard rods.
Possibly what CuP alloys was talking about ?
