Posted by Eric Cox on 16/01/2017 09:59:53:
What happened to the Middleton V4 article in ME4552.
On page 149 the first section talks about setting the metal in a four jaw chuck with a 15mm off set then says make sure it's running true and turn to 45mm Dia.
Makes perfect sense to me. It's not the way I would personally do it but I can see what the author is suggesting and that would work.
Fig 9 on page 151 bares no relationship to the text.
See above post
The fly wheel on the same page suddenly goes off at a tangent talking about scribing the the steam passages on the side of the cylinders.
Yes another heading after the first paragraph may have been a good idea
What happened to proof reading ?
If you want the cost of teh mag to go up then I'm sure a proof reader can be employed, Diane only has so much time that has to be spread over teh whole mag that things will slip through. If you had seen the original article as submitted then you would be praising her for making it into its present form.
J
Edited By JasonB on 16/01/2017 13:46:30
Edited By JasonB on 16/01/2017 13:48:49
