At the risk of causing confusion, here are my comments.
You will find that your horizons expand, and need a larger machine.
A Leadscrew allows you not only to screwcut, but to set up a power feed, which can improve the turned finish.
Although a mini lathe is liable to be Metric, a 63T gear will allow Imperial threads to be cut, should you need anything larger than those that can be produced using Taps and Dies..
The suggestion of having a mini lathe on a roller cabinet is a good one. The cabinet results in additional bench space, which can be moved around yo suit your requirements at the time.
My mini is on one and the drawers provide lots of storage for tools, a spare chuck. (3 or 4 jaw jaw, depending on which is in use ), ER collet chuck, faceplate, change wheels, etc.
You can get a Vertical Slide for the mini lathe which will allow a limited amount of milling.
if you require, a radius turning attachment, they are available.
By all means gain experience with a micro lathe, but a mini is likely to more useful as time goes on.
