Posted by Michael Gilligan on 31/05/2016 13:59:42:
Posted by Ajohnw on 31/05/2016 12:22:27:
My Olympus's don't throw a wobbly when I press the lens release button. Just tried it to be sure.
John,
Are you saying that Auto and Manual focus both still work properly with the lens release button pressed
… or just that you didn't get a warning message
Details may differ between Olympus and Panasonic, but, on the DMC-G1 the warning message does not appear if 'shoot without lens' has been set [except when 'intelligent Auto' is selected] … but the lenses don't focus.
… Your experience appears contrary to peak4
P.S. Both lenses work fine on my other two bodies, so I certainly won't be bending any contacts in the hope of improving things.
Edited By Michael Gilligan on 31/05/2016 14:04:48
Michael, The Oly menu system is rather different to the Panasonic.
For one thing, there is no "shoot without lens" option.
For a purely manual lens, you just set the focus to Manual, and exposure to AP or Manual. In Body IS can be manually set according to the focal length of the lens.
On an m4/3 body with an m4/3s lens, depressing the lens release button on the body kills communication with the lens;
the aperture shows as -.-
the focal length goes to —
the EVF goes black, and the shutter release doesn't trip.
On a 4/3 body with a 4/3 lens pressing the lens release button kills the aperture display again; It doesn't focus either, but the shutter does trip, though the lens does stop down.
A manual lens, such as an 8mm Peleng, works fine on either m4/3 or 4/3 cameras, with the appropriate adaptor, and operates in MF, with either AP or Manual metering modes.
Neither throws a wobbly as such, but neither does it work correctly.
You don't get a warning message as such, the giveaway for the location pin not being quite home is the lack of aperture information in the Viewfinder/Monitor/LCD
Regarding whether the lens will Auto or Manual Focus with the release button depressed. AF doesn't work. Manual depends on the lens, some are purely fly by wire, in which case they won't MF, some have a clutch, in which case they will.
There's much more to it when you start interspersing extension tubes or teleconverters.
Edited By peak4 on 31/05/2016 21:40:39
