MEW Index updated to Issue 310 (December 2021)
Home Forums Model Engineer & Workshop MEW Index updated to Issue 310 (December 2021)
  • #572369
    David Frith
      @davidfrith72923
      The MEW index to issues' #1 – #310 is out
      The pdf contains two lists, one sorted by issue number and the other sorted by author/contributor.
      Excel version from here:
      https://docs.google.com/spreadsheets/d/1vCenMkL8v4YftIsXJ15sjSuMmdvJvZrG/edit?usp=sharing&ouid=116999386607617355203&rtpof=true&sd=true
      PDF version from here:
      https://drive.google.com/file/d/1mzF62KHsr0wgMx5_odPh5NzGjo_fUhw5/view?usp=sharing
      David Frith
        @davidfrith72923
        Downloadable pdf and Excel files for the Model Engineers’ Workshop Index
        #572396
          star
          Keep them coming, David
          Howard Lewis
            @howardlewis46836
            ODD!
            I can copy the references from then thread, but not paste them into Google.
            However, the copies of the references will paste onto a WORD document.
            The references can then be copied from that and pasted into Google, to call up the Index.
            Maybe this is a quirk of my anti virus software?
            #572503
            Howard Lewis
              @howardlewis46836
              EXTREMELY useful to locate an article on a particular subject, ( and the Issues ) in which it / theywere published.
              Thank You!
              #572506
              David Frith
                @davidfrith72923
                Hi Howard, are you pasting into the Google search box rather than the address bar of the browser?
                I've tried the addresses with several browsers, even some old versions without a problem.
                Glad you find it useful though. I'm also looking at a possible database solution where the user can add their own info for searching stuff. TBD
                #572671
                Howard Lewis
                  @howardlewis46836
                  Hi David!
                  Thanks.
                  The link would not paste into the Google search box, but would into a WORD document, From there it could be pasted into the Google search box and than appeared as requested.
                  So problem solved !
                  Am going to spend a lot of time looking through it, and finding "That article somewhere" when needed
                  #572688
                  Anonymous
                    Howard, if you highlight the link in the post, right click and select "Open Link", you should go straight there.
                    I think this works in all browsers.
