MEW 196 – RPM Sensor, Page 42
Home Forums Model Engineer & Workshop MEW 196 – RPM Sensor, Page 42
  • #103803
    J. Becker
      @j-becker22751
      Based in Germany, I have not found a supplier for these sensors. Where can I buy a reasonably small number, say, five or six? NVE, the manufacturer sells them by the reel (thousand pcs).
      I have searched farnell and ebay without any success.
      Thank you.
      Jochen
      J. Becker
        @j-becker22751
        Gear Tooth Sensor AKL001-12
        #103911
        Sub Mandrel
          @submandrel
          HI Jochen,
          Consider using **LINK** this produces a logic-level output unlike the original sensor so you will need to kmake some changes.
          I use these for my rpm sensors and they woprk really well.
          john swift 1
            @johnswift1
            Hi Jochen
            the first supplier in Germany I've found is Digikey :-
            Edited By john swift 1 on 16/11/2012 22:00:15
            #109051
            Simon Fedida
              @simonfedida18373
              Hi –
              re the hall effect sensor – I'm also looking for a UK supplier, small quantity. The Allegro unit from Farnell is OK but I would rather have an analogue ouput device to interpolate between teeth.
              NVE make an analogue variant of their sensor, but like Jochen, I can't find a supplier.
              Simon
