MEW 193 — Wooden CNC Mill
Home Forums Model Engineer & Workshop MEW 193 — Wooden CNC Mill
  • #38140
        I must congratulate Richard Gordon
        His article is extremely well written and illustrated, and the design is truly ingeneous [which is, of course, the root of engineering].
        Using readily available materials and basic hand tools, he has produced a machine capable of significantly better accuracy than the tools that made it.
        I am unlikely to build this machine, because I already have a BCA Mk. III, but that's not the point: It is an interesting project, that makes us think … i.e. exactly what MEW needs.
        It would make an ideal project for Schools or Clubs, and may also be of interest to the "Appropriate Technology" folks who assist developing countries.
        Thank you, Richard
        David Clark 13
          @davidclark13
          Hi Michael
          Thank you for your support.
          I was expecting complaints about how wood is not suitable for making a mill etc.
          regards David
          #95784
          Tony Jeffree
            @tonyjeffree56510
            Posted by Michael Gilligan on 05/08/2012 08:39:43:
            Thank you, Richard
            I agree – an excellent article.
            Tony
            #95785
            Tony Jeffree
              @tonyjeffree56510
              Posted by David Clark 1 on 05/08/2012 08:48:24:
              Hi Michael
              regards David
              Nothing at all wrong with wood – it was after all one of the earliest engineering materials. It is a good choice for making light duty machines – for example, it would make a good choice for something similar to the RepRap machines, and was the subject of a light duty router design in MEW fairly recently. As Michael observed, articles like this stimulate the brain cell.
              Tony
              #95786
              Ady1
                @ady1
                The key elements in the mix are probably a shortage of accepted materials(ww2 austerity) and some good old British ingenuity
                wood was unsuitable for front line fighter bombers too
                http://en.wikipedia.org/wiki/De_Havilland_Mosquito
                Edited By Ady1 on 05/08/2012 09:09:16
                #95945
                Tony Jeffree
                  @tonyjeffree56510
                  Just spotted a slight typo in the text of the wooden mill article – the author wrongly refers to the spindle unit that he is using as being from a Sherline mill; it is in fact a Taig (Peatol) mill spindle, which would be obvious to any Taig or Sherline users reading the article, but might confuse others.
                  Tony
                  #95946
                  David Clark 13
                    @davidclark13
                    Hi Tony
                    Are you sure?
                    If so I can print a correction in MEW 194.
                    regards david
                    #95948
                    Tony Jeffree
                      @tonyjeffree56510
                      Posted by David Clark 1 on 08/08/2012 14:40:32:
                      Hi Tony
                      Are you sure?
                      regards david
                      Hi David –
                      Absolutely positive. Compare the views in photos 15&16 with the photos on the Taig website here:
                      In contrast, check out the Sherline mill here:
                      The shape of the pulley cluster & the longitudinal T-slots on the Taig headstock are a dead giveaway – also, I don't believe Sherline do an integral ER16 chuck on their spindles.
                      Tony
                      #95951
                      Gray62
                        @gray62
                        Hi Tony,
                        If you check the Sherline catalogue, you will find that they do (or have in the past) an ER16 spindle with either a 'cog' belt drive or step pulley drive.
                        Not sure if they are still available but they were!
                        Just to throw yet another spanner in the ME works LOL
                        Taig also produce an ER16 spindle
                        CB
                        #95956
                        Tony Jeffree
                          @tonyjeffree56510
                          Posted by CoalBurner on 08/08/2012 17:39:44:
                          Hi Tony,
                          CB
                          Hi CB –
                          You're right – you can order an ER16 Sherline spindle as a special; however, the standard Taig spindle for their mills is the ER6 version these days – and that is the one used in the article.
                          Tony
                          #95965
                          Sub Mandrel
                            @submandrel
                            I'm assuming that the mill author is the Richard Gordon who designed and made Nano and some other impressive models as a teeneager?
                              The confusion regarding the Spindle Unit continues in MEW 194
                              The Author gives a specific reference to Sherline Part 30111
                              This is listed as an ER-16 Headstock Assembly … but , as Tony said [and he should know], the one illustrated in MEW 193 was a Taig/Peatol.
                              It doesn't really matter, but it does seem rather odd.
                              … Perhaps David could ask Richard Gordon to clarify.
