Contrary to common belief the world is not and may never be Metric ! Many things are still for various reasons made in imperial dimension, structural steel, aluminium, pipe fittings Etc Sitting on the bog at afriends house in Belgium the gas main had 1.25″ cast into the fitting. Ah well. Noel
Um… Noel; no argument there.
However, I, too, would built a Stuart engine with metric fasteners; cheaper than ordering in BA taps and dies from overseas. I’ve got a fantastic set of Metric, pretty good UNC/UNF, but minimal BA/ME, so why not use what you are comfortable with?
Currently finishing a Martin Evans “Ivatt” locomotive, bits made in NZ, NL, and Canada; all dimensions converted from fractions/decimals into mm.
My first locomotive was in BA and inch; after I lived NL for a while, I found the metric system for machining much easier.
Others prefer inch, but so what? It’s the end product that counts.
Respectfully, Another JohnS.
