Hi,
I need to secure a steel trigger wheel to an aluminium crank pulley.
The pulley and trigger wheel will be bolted to the crank (already sorted that bit) but I needed a way of ensuring that the trigger wheel does not move around its centre in relation to the pulley, otherwise the engine timing will be thrown out.
So I thought at first a dowel pin, but for added securing I thought I'd rather put in a screw.
The pulley outer ring is about 15mm.
I am thinking a couple of M4 button head allen socket bolts, but will a metric thread be OK? The idea is that I will drill through the trigger will 4mm and then drill and tap the pulley below for an M4 bolt about 6mm deep.
So first up what are the thoughts on the above plan?
Secondly – I got confused and thought I would need a UNC threaded bolt as on these engines bolts in aluminium are UNC. A colleague suggested 3/16 UNC, but I am having problems finding the correct tap and drill for 3/16 UNC.
The trigger wheel is 5mm thick.
In the pic above most of the bolts that secure the trigger wheel to it's centre boss have been removed temporarily.
