Posted by John Stevenson on 17/11/2013 12:27:56
can set to do 50mm radius but where do you set 100 units ?
John,
Sorry; I should have clarified … These are designed as "Setting Circles" [primarily for telescopes, etc.] and, by default, they are calibrated in degrees, from 0-360.
Unfortunately the free version doesn't allow much manipulation … but you can get 0-100 markings by cheating a bit.
There isn't room on an A4 page to do 50mm radius, but this works OK for 40mm.
40 x 3.6 = 144 so tell it to use 144mm radius; set the paper size to A4 portrait; and the Y-origin at 25mm [to just clear the footer text] … The print will effectively spill off the top of the page, leaving 100 available to wrap round a 40mm drum.
Nice clean pdf … without registering on the site.
Probably not much use if Graham needs 50mm radius; but at least it demonstrates the concept.
