Well, I have always thought the Americans were sensible because they tended to mostly use decimal fractions on their drawings, and, even more important, used third angle projection. I alway though the arguments in vavour of first angle were pretty specious…yes, if I put a semi transparent version of the object in a box and shine a light through, I will get the top view at the bottom, the left view at the right, and so on. However, that is not actually how I use the drawing, and being human I tend to look for the view of the left hand side on the left, where it would be in real life. The only thing about American drawings I have not liked is those funny fasteners…how big is 10-32 anyway? But BA is open to the same objection.What I don’t like is having to add up a string of inch fractions to arrive at the actual figure to machine. You know the sort of thing, 5/8 +13/16 + 7/32. (Now was that supposed to thirteen sixteenths or one and three sixteenths…?)
On the Pi thing, may I (hopefully) clarify things a little. Pi is an irrational number. In mathematical lingo, that means that it cannot be expressed as a whole number fraction. There is no pair of whole numbers a/b that will equal Pi. The same is true for the square root of two, “e” and a whole lot of other interesting numbers. A decimal fraction is still a fraction, just written differently to save space. For example 0.123 = 123/1000. It follows that there is no decimal fraction, no matter how long, that exactly expresses Pi, or root 2 or e for that matter. As engineers this does not matter to us, since nothing we make is actually perfectly circular anyway, and we can rarely measure things to better than four digits accuracy anyway.
On the original topic, I think we are at the point now where metric should be the preferred system for all new work . Yes, the system is not without its idiosyncracies. I grew up with Imperial, have worked in both, and find I prefer metric.
regards
