Metric or Imperial
Metric or Imperial
Home Forums Workshop Tools and Tooling Metric or Imperial
Viewing 25 posts - 1 through 25 (of 36 total)
  • #17214
    Oompa Lumpa
      @oompalumpa34302
      Oompa Lumpa
        @oompalumpa34302
        First off – this is not a criticism, more a bemused observation.
        I have recently bought a Century Mill in "as new" condition. It has the X and Y handwheels, as you would expect, in fractions (which is a bit confusing to be honest 1000ths would have been better) but now I have noticed that both the Z axis and the Quill fine feed are in Millimetres?
        Is this normal or am I missing something?
        A scale in Millimetres or even 1000ths of an inch would be good – are such things available? A "stick-on-Scale"?
        graham.
        #135734
        Oompa Lumpa
          @oompalumpa34302
          Sorry, the Mill is in the "Imperial" configuration hence I say "as you would expect" Just for clarification.
          #135736
          Sub Mandrel
            @submandrel
            ! I didn't think any modern machines had fraction dials!
            How many graduations on the dial and what pitch leadscrews. If 64 graduations and 1/16", then close enough to a thou over short distances (e.g. for applying a cut) but over 2% error so no good for precision work over more than about 1/4 – 1/2". My lathe has a 1/16" pitch leadscrew and I have this annoying issue.
            The other leadscrews on my lathe are 1mm/40 division and 0.025mm is close enough to 0.001" for most things.
            A 1.5mm pitch leadscrew with a 60-division (0.025mm) handwheel gives the same 0.3% error, so is usable over a couple of inches for most purposes. My mill has the 1.5mm pitch leadscrews, but the handwheels have 75 0.02mm divisions making imperial work a mind-bender. I must fit 60 division handwheels…
              My old imperial Emco lathe had a handwheel on the end of the leadscrew with 125 divisions of 0.0005"each eg 16tpi. Can you post a picture as unless its a very coarse leadscrew you won't get many divisions even if its 128ths of an inch.
              For a stick on scale why not stick on a DROwink 2
              Edited By JasonB on 16/11/2013 20:32:53
              #135738
                Just had a look on the Chester forum and some of there other mills have 0.0625 div handwheels on 16tpi leadscrews which is indeed a PITA so quite likely teh century is the same in which case a DRO is the only real way to sort it apart from changine to metric leadscrews, nuts and handwheels which are likely to be 2mm pitch, may explain why it was for sale.
                J
                Edited By JasonB on 16/11/2013 20:47:20
                #135741
                mickypee
                  @mickypee
                  Why not fit the machine with a DRO which will have an option to switch between metric and imperial. Probably cost around £400 which you might spend converting the machine any way. Very accurate and takes care of any wear that it might have. I have DRO's on my mill and both lathes, couldn't imagine life without them.
                  #135758
                    Just an aside …
                    It was quite common, until at least the mid-1960s, for American draughtsmen to work in 1/128ths of an inch.
                    I had hours of fun trying to understand all the strange dimensions on the drawings for a Polaroid 5×4 film holder … until I realised that it had been designed in 1/128ths and then later "modernised" to decimals. Once I had reverse-engineered the "rounding", the design made sense.
                    Oompa Lumpa
                      @oompalumpa34302
                      Thank you for all your replies, I am pleased to see it wasn't just me. A DRO is of course on the cards but so is a great deal of other tooling and you can only buy so much at a time.
                      I am really quite pleased with the machine, it has opened up a great many new avenues to me. It doesn't matter which one you buy, from the smallest to the biggest, they will all have their shortcomings, I am happy with what I have so I will work with that.
                      Bloody annoying though
                      #135762
                      Sub Mandrel
                        @submandrel
                        Oompa – you could print out temporary 0.001" graduated scales, get them laminated and fix them to your dials, until you get a DRO, cheap or expensive.
                        Oompa Lumpa
                          @oompalumpa34302
                          Posted by Stub Mandrel on 17/11/2013 09:33:27:
                          Yes, I think I would like to do that Neil, is there some sort of formula? I am not yet that dim witted that I could work it out myself but if there is a "quick and dirty" solution I would go with that.
                          Right now I would like to reserve whatever grey matter is left for important stuff, like should I have one bacon sandwich or two this morning?
                          #135764
                          NJH
                            @njh
                            Oompa
                            Free up you brain's resources – don't even think about it – go for two!
                            N
                            #135765
                              Try here … this is much better than "quick and dirty"
                              IanT
                                @iant
                                You do seem to find some interesting places out there in Webland Michael.
                                Thank you for this one – I'm sure it will come in handy one day (added to favourites!)
                                IanT
                                #135777
                                Bazyle
                                  @bazyle
                                  Rather than expensive full DRO you may be able to set up a cheap tyre gauge to gvie you the digital readout for fine control Just go to the nearest whole number '0' with the existing dial, lock the gauge holder somehow, zero it, and you have a DRO for the last bit that is difficult.
                                  #135779
                                  John Stevenson 1
                                    @johnstevenson1
                                    Posted by Michael Gilligan on 17/11/2013 09:51:39:
                                    Can't see a way to do a linear strip with say 100 division on a set radius ?
                                    #135781
                                      Posted by John Stevenson on 17/11/2013 11:58:12:
                                      Really ?
                                      #135782
                                      Oompa Lumpa
                                        @oompalumpa34302
                                        Posted by NJH on 17/11/2013 09:47:54:
                                        Oompa
                                        N
                                        I went for the Double Decker, bacon and egg in the end
                                        #135783
                                        Oompa Lumpa
                                          @oompalumpa34302
                                          Oh it's there allright.
                                          Great link by the way, thank you for that. Off to measure the radius of the wheels right now………
                                          #135784
                                          John Stevenson 1
                                            @johnstevenson1
                                            Posted by Michael Gilligan on 17/11/2013 12:11:22:
                                            Really ?
                                            OK having a thick day,
                                            can set to do 50mm radius but where do you set 100 units ?
                                            #135787
                                            Oompa Lumpa
                                              @oompalumpa34302
                                              Nope – tried all that, wants $15 annually to print out a linear scale.
                                              I will resort to that old standby, math.
                                              graham.
                                              (PS – I am not a cheapskate by any means but I have better uses for a tenner other than this.)
                                              #135789
                                              Bazyle
                                                @bazyle
                                                IN around 2001 I had a free version of Turbocad that would step and repeat round a circle to make dials, not just the ticks but numbers too. Do any of the current free CAD programs do that?
                                                #135798
                                                  Graham
                                                  Sorry I spoke
                                                  … it's easy enough to do manually.
                                                  Edited By Michael Gilligan on 17/11/2013 14:09:16
                                                  #135799
                                                  John Stevenson 1
                                                    @johnstevenson1
                                                    No idea not heard of this but the program I use, Fastcad, has a macro called DIV where you select a line, type in how many division you need and it puts a small line at each division.
                                                    Simple job from there to trim to the lengths needed, Numbers will be have to be added manually.
                                                    Have half an idea that the CNC Utilities program has a sub routing to get G code for this, not got it on this laptop so can't check.
                                                    #135801
                                                    Oompa Lumpa
                                                      @oompalumpa34302
                                                      Hey Michael, please don't take offence. You link was great, just the guy was being a little OTT in my opinion with regard to the tenner for a dial sticker.
                                                      Obviously he wants to get paid for his efforts and good luck to him. Just not for me right now. He has obviously put some great effort into this and I can see people would take advantage if this is a business model.
                                                      Thank you for taking the trouble to point it out though.
                                                      graham.
