Posted by Hopper on 02/03/2021 07:58:10:
So this is the cross slide feed screw?
Sounds like a Myford special made as a cost saving measure on their imperial thread roller fitted with metric rollers, if it is in fact 3/8 diameter and 2mm pitch. If so you have three choices:
1. Buy new Myford parts, if / when available — at the Myford price.
2. Substitute some 10mm x 2mm pitch trapezoidal threaded bar and matching nut which is readily available but will need machining to suit the Myford handle and dial and the nut will need modding too. Or make your own nut using tap from Tracy Tools etc.
3. Repair the existing damaged screw, which you have not described in detail. The usual dodge is to cut the handle end off the screw, flip the threaded section around 180 degrees and attach handle to the other end. Usually done by drilling and reaming a hole in the ends of each piece and inserting a pin to join the two pieces, which is then silver soldered, loctited or pinned in position.
Edited By Hopper on 02/03/2021 07:59:15
I have such metric screws on my machine for a long time and there are no issues with them.
When I made an upgrade to long cross slide and "modern" looking top slide long time ago I got it all in metric forms.
However my friend brought to me damaged (bent) metric feedscrew from his topslide and asked me to make duplicate.
Then I have started measuring and found something weird – mixed metric – imperial design.
Myford sells them but they are calling close to 1000 quids on ebay (!!!) and anyway "new Myford" stuff usually is not really a match for original parts.
Once I have ordered myself replacement tailstock barrel and it came with badly scored 2MT socket, damaged as new.
After complaining they replaced it but meantime I have made one myself, even better in quality than what they sent and also made of 45 HRC material but with only short section of ACME thread – suitable for lever operated tailstock.
