Granville, we have two metal spinning companies in the locality, James and Spackman (I think that is the name but spelling may not be correct!) who are located near Sellinge I believe and one on the Isle of Sheppy. A freind has a drawing in with both at present for a quote (full size TE part). The former so far have failed to respond, the latter were helpful with suggesting various options but their price was not cheap! If you want the contact details email me and I will get them for you.
I am not sure on the exact shape you need but on the Ruston I made the parts from 3mm and welded the return on with a fillet on the inside corner then radiused the outside off with a file so it looked like a pressed plate. If it's possible to develop what you need by a similar method I may be able to put you in touch with a man who could TIG weld it so you could use thinner plate.
Last suggestion is turn a wood former and spin it yourself, but in copper, easier to work and as it will be painted no one will know what it's made of unless they run a magnet over it!
Paul.
