Posted by John Doe 2 on 03/05/2022 10:21:13:
Can I just say, ChrisB, what a nice installation you have built there ! Good engineering to keep the heatsink cooling air completely separate from the electronics, and well done for lining up the front panel with the circuit board switches – that must have taken a couple of attempts.
And proof, if it were needed, that the front panel switches of a VFD are not designed for heavy use – you can see (the five yellow dots near the readout display); they are just tiny circuit board switches, not designed for heavy regular workshop use.
Thanks John. Yes alligning the front panel to the buttons was a pain, an exercise of measure a thousand times, cut once and trim a bit more!
I wanted the vfd to be easy to connect and disconnect because I plan to use it for other machines I plan to build, and good quality vfds don't come cheap!
