Message to the Webmaster!
Home Forums Website Questions, Comments, and Suggestions Message to the Webmaster!
Viewing 25 posts - 51 through 75 (of 111 total)
  • #85075
    NJH
      @njh
      Why are you posting 3 Meg high res images?
      I have asked previously for some guidance from this site on image file size but, even being very generous, I doubt that folk have monitors capable of showing any difference in a file of say 500K and one of 3 Meg. In fact a file of 200 – 300K is probably quite sufficient.
      I know the site software limits the size but there is no point in squirting un- necessarily big files down the line is there.
      Mark Web Tech – perhaps you could comment.
      Sorry, you've had a bit of a rough run so far, but it is the weekend soon!
      Cheers
      Norman
      Gone Away
        @goneaway
        Mark, any comment on the fact that the editor seems to hijack the right mouse click preventing use of external (browser) spelling checkers? It does this whether or not SCAYT is enabled.
        #85077
        John McNamara
          @johnmcnamara74883
          Hi Mark
          You tube embed
          Cheers
          Epoxy Mill I am working on
          Unlimited Free Image and File Hosting at MediaFire
          #85078
          John McNamara
            @johnmcnamara74883
            Hi Norman
            Unless you click on an image the image is a small size. If however you click it then it will go and get the larger image. So it is a matter of choice. Bandwidth is not used unless you ask to see more detail.
            Cheers
            Mark Web Tech
              @markwebtech33648
              John that looked like it worked using the YouTube embed method. Were you OK with that process?
              M
              #85080
              John McNamara
                @johnmcnamara74883
                Hi Mark
                515×385 image
                #85081
                John McNamara
                  @johnmcnamara74883
                  Much better Mark it allows you to click and see the images on the site
                  Can someone see if the image can be downloaded from mediafire please
                  Cheers
                  Edited By John McNamara on 17/02/2012 15:53:09
                  #85082
                  Mark Web Tech
                    @markwebtech33648
                    John I Think the 515 looks best, the image will get scaled to 350px anyway by the style sheets on the website.
                    M
                    #85083
                      Posted by John McNamara on 17/02/2012 15:52:51:
                      If I click the image it opens mediafire in another window and shows the image the same size as in your post. If I then click download it gives an image that fills the screen height wise but is still a small 75k file size.
                      Edited By JasonB on 17/02/2012 16:09:03
                      #85085
                      John McNamara
                        @johnmcnamara74883
                        Hi Mark
                        Large scale check
                        #85086
                        Mark Web Tech
                          @markwebtech33648
                          Hi everyone I've just added a new icon to let you add an image in from your Albums, which should work in the same way as the old editor worked. Hopefully it'll help.
                          M
                          #85087
                          John McNamara
                            @johnmcnamara74883
                            Thank You JasonB
                            You must have downloaded the CAD screenshots they are quite small any way.
                            If you had downloaded one of the photos and you had selected large you would have got about a 3mb file.
                            Mediafire actually allows you to download large medium or small size images.
                            Cheers
                            John McNamara
                              @johnmcnamara74883
                              Gee Its late down under.
                              Better sign off and get some shut eye……
                              Good to work with you Mark, you are making progress. Email me if I can help with any test
                              Cheers
                              Ketan Swali
                                @ketanswali79440
                                Posted by Ketan Swali on 17/02/2012 14:44:17:
                                Posted by John McNamara on 17/02/2012 14:14:59:
                                Hi All
                                It is nice to see the adds dissapear as you scroll down the page!
                                Cheers
                                So I guess that we should be asking for a discount then..?..smiley
                                Ketan at ARC.
                                Any comments Mark Web tech please ?
                                Posted by Mark Web Tech on 17/02/2012 14:49:36:
                                Ketan I'm not sure what the problem is here.
                                M
                                Sorry Mark,
                                There is no problem with reference to ads. After reading John Mc's comment, I got the wrong idea that something had changed for the ads column, but after checking on "waybackmachine", I note that with reference to ads, it is still the same. Sorry for the confusion in this respect.
                                Thanks, Ketan.
                                #85095
                                maurice bennie
                                  @mauricebennie99556
                                  Hi David Mr moderator sir ..Its just that often ,when I turn on the adverts on the right hand side of the screen are covering the threads .today ,after scrolling done they went back to where they should be and I dont know why .Is it something Im doing or not .as you can see Im not too bright no computers.
                                  Thanks for trying to help Maurice.
                                  #85102
                                  David Clark 13
                                    @davidclark13
                                    Hi Maurice
                                    It sounds like your computer settings.
                                    We do get adverts over the threads but usually they stay like that until we fix the long link that caused it.
                                    You seem to be the only person with intermitent problems.
                                    regards david
                                    #85104
                                    clivel
                                      @clivel
                                      Oh this is getting ridiculous!!
                                      I just about completed a long posting in another thread, I only needed to add a Web Link. Clicked on the "Link" button, only to be presented with the "white screen" and could do nothing but press the browser back button, losing everything I typed angry
                                      To say I am unimpressed is an understatement!
                                      P.S.
                                      SCAYT (what an intuitive name for a spell checker) defaults to US spelling. One would have expected a UK based web site to default to British spelling. There really seems to be no rational reason for having disabled the fully functional Firefox spell checker that is allowed by every other web site.
                                      #85111
                                      mike T
                                        @miket56243
                                        Dear Mr Moderator,
                                        Why do you insist on saying it is our computer settings which are at fault? Have you considered that you may have replaced a less than perfect Editor with this one which is, to say the least, even further than perfect. Do you think it is time to ask for your money back?
                                        #85113
                                        Ian P
                                          @ianp
                                          Posted by David Clark 1 on 17/02/2012 21:20:01:
                                          Hi Maurice
                                          regards david
                                          Poor Maurice!
                                          David (DC1)
                                          Your reply reads as if its only Maurice that is seeing problems. Just because other users post details of every anomoly they see (and then don't see) does not mean that Maurice is the only one with intermitent problems.
                                          The very size of the response to this thread should give you and 'M' some idea of the extent of trouble the forum participants are going through. Yes, I know we are here as 'guests' and we can always switch the computer off if we want to but I think now that MEW has gone to the trouble and expense of setting up the forum it should at least think of the users.
                                          The next thing I want to say is not easy to put into words and I do not want to cause offence, but, earlier we learnt that MEW does have a website manager (I'm not sure of the correct terminology and I dont want to lose what I'm typing now by searching), surely Mark should be the one communicating analysis and advice rather than yourself?
                                          Personally I would rather be engineering than typing this, but this whole affair has now become a bit of a saga and I'm addicted.
                                          Ian P
                                          #85114
                                          Mark Web Tech
                                            @markwebtech33648
                                            Posted by mike T on 17/02/2012 22:20:23:
                                            Dear Mr Moderator,
                                            Mike T if you're experiencing any specific issue, please reply to this message with the details of what's happening and what browser/OS you're using. I'm happy to look into any issues our members are having, but require a bit more information to go on.
                                            M
                                            #85115
                                            Ian P
                                              @ianp
                                              I hope this is just a pure coincidence.
                                              When I pressed return posting my previous message (2 minutes ago) the screen refreshed but with adverts right down the middle of the screen! in front of the forum window which now has text wider than the screen so to read it I have to scroll from side to side.
                                              This the first time ever that I (me) personally have seen adverts in front of the text. I've read about it here, but its never happened on my PC.
                                              Things seem to be going downhill rapidly.
                                              Ian P
                                              #85116
                                              Nicholas Farr
                                                @nicholasfarr14254
                                                Hi, so far I think the spell checker is rubbish, and agree which Clive about the US English, and not being able to use the browser spell checker.
                                                I can't seem to find how to turn the compatability view off, I'm using IE9 on Vista.
                                                Regards Nick.
                                                #85118
                                                Mark Web Tech
                                                  @markwebtech33648
                                                  Posted by clivel on 17/02/2012 21:46:30:
                                                  Hi, I've just changed the default language of the spell checker to British, thanks for pointing it out.
                                                  M
                                                  #85119
                                                  Ziggar
                                                    @ziggar
                                                    Testing
                                                    Using an iPad
                                                    ipad spell checker working fine
                                                    Below are two test links that go nowhere.
                                                    http://Goesnowhere.com
                                                    Test link
                                                    Edited By Ziggar on 17/02/2012 22:46:23
                                                    #85120
                                                    mike T
                                                      @miket56243
                                                      Hello Mark Web Tech,
                                                      Curently, and things do change, I have adverts down the centre of the page and text that is wider than my screen. I am a model engineer not a computer fanatic, so browsers and firefoxes and Scayt spell checkers mean little to me. I have Widows XP and Windows Internet Explorer, Please do not even think about advising me to change these just to see this forum
