Message to the Webmaster!
Home Forums Website Questions, Comments, and Suggestions Message to the Webmaster!
Viewing 25 posts - 26 through 50 (of 111 total)
  • #85039
    David Clark 13
      @davidclark13
      Hi Terry
      Last time I asked about the editor I was told it was £3,000 to replace.
      This was a long time ago though.
      regards David
        Mark
        When I try to add a link or an image by clicking the icons the active window goes foggy as several others have said elsewhere can something be done about that.
        I'm on IE9 and Vista.
        Also just tried to add a reply from my phone and all I get is a rectangular box to type the reply into with no icons at all. (HTC)
        J
        Edited By JasonB on 17/02/2012 13:15:14
        #85049
        Mark Web Tech
          @markwebtech33648
          Hi Jason, make sure you're not using Compatibility view in IE, as that was a work-around required for the old editor, but you don't need to do so with the new one. It's working fine for me in IE9, I'm using Windows 7 though, but would imagine it would work in the same way.
          M
          #85050
          Mark Web Tech
            @markwebtech33648
            Jason, from devices which don't support the full-blown text editor, like some phones, you should instead see a normal text input box. You can't add in special formatting or anything, but it should enable you to at least get a plain-text posting in, if you need to post before you get back to your proper computer.
            M
            #85052
            Ketan Swali
              @ketanswali79440
              Posted by David Clark 1 on 17/02/2012 12:08:04:
              Hi Terry
              regards David
              David,
              Dont beat yourself over it. I am guessing that the accounts probably included the implementation costs (human labor) when they gave you the figures.
              Ketan at ARC.
              #85053
              maurice bennie
                @mauricebennie99556
                Hi everyone, I have tried to follow the discution and now totally baffled. Being not computer literate I am lost. If the people , who obviously know what they are talking about , are unable to operate the system ,how are us lesser mortals going to fare.I have had problems in working the system and have asked my daughter ,who works on computors all day ,to help me, but to no availe.Please make it a bit easier to understand.Iam on WINDOWS XP whatever that is. Maurice
                #85054
                John McNamara
                  @johnmcnamara74883
                  Hi all
                  Test of text with a linked image at a remote file server
                  cheers
                  Wire Alignment microscope
                  Wire Alignment
                  #85055
                  Mark Web Tech
                    @markwebtech33648
                    Hi Maurice, what exactly are you having problems with? I can see your post here, so I guess you're able to post normal messages.
                    Thanks,
                    M
                    #85056
                    John McNamara
                      @johnmcnamara74883
                      Hi All
                      No go the image was distorted.
                      Hi All
                      I unclicked then reclicked lock ratio
                      Still no go.
                      Cheers
                      Wire alignment jig
                      Try again
                      Edited By John McNamara on 17/02/2012 14:08:28
                      #85057
                      John McNamara
                        @johnmcnamara74883
                        Hi all
                        So the image tool is broken, the image is distorted.
                        With the old editor if you clicked on a linked image it expanded and filled the screen.
                        With the new editor nothing…….
                        Cheers
                        Edited By John McNamara on 17/02/2012 14:10:49
                        #85058
                        maurice bennie
                          @mauricebennie99556
                          Hi I have just started to read the messages and the adverts are again covering over the messages and I cant seem to remove them ,this often happens to me and I dont know how to fix it ,and seemingly other simple things like this. Maurice
                          #85059
                          John McNamara
                            @johnmcnamara74883
                            Hi All
                            It is nice to see the adds dissapear as you scroll down the page!
                            Cheers
                            maurice bennie
                              @mauricebennie99556
                              Hi John So it happens to those who know how it all works,thats nice to know
                              Not quite in despair now Thanks Maurice
                              #85061
                                Mark
                                Just took off compatability view and I can now get the icons to work
                                BUT
                                It has now made john Mac's images distorted, they were OK when comp view was on.
                                Can't see his pics at all now.
                                J
                                Edited By JasonB on 17/02/2012 14:30:28
                                #85062
                                John McNamara
                                  @johnmcnamara74883
                                  Hi Mark
                                  Web Tech
                                  The source file for that image is 3MB High Resolution
                                  I stored it on mediafire as a Live link
                                  A user should be able to click on it and see the high resolution image.
                                  Cheers
                                  Mark Web Tech
                                    @markwebtech33648
                                    John,
                                    To avoid the resizing thing happening, this is what I did:
                                    1. Click on Image button
                                    2. Paste the URL into the URL box and then press tab or click into another field, so that the system goes and fetches the image and puts it into the preview box
                                    3. Click into the Width box and type in 350. This will automatically adjust the height accordingly
                                    4. If you want to add in a link to the image, click on the Link tab and paste the URL into the URL box on that tab too
                                    5. Click OK
                                    Example:
                                    M
                                    #85064
                                    John McNamara
                                      @johnmcnamara74883
                                      Hi Mark
                                      Not a good idea. the system should default to the correct size.
                                      As the previous system did.
                                      If someone wants to see a bigger image then they can double click the image.
                                      Cheers
                                      Ketan Swali
                                        @ketanswali79440
                                        Posted by John McNamara on 17/02/2012 14:14:59:
                                        Hi All
                                        Cheers
                                        So I guess that we should be asking for a discount then..?..smiley
                                        Ketan at ARC.
                                        #85066
                                        John McNamara
                                          @johnmcnamara74883
                                          Ah Ha
                                          If you simply ise the link tab and nothing else the image is correctly downsized and it enlarges when you click it.
                                          Cheers
                                          Hohn
                                          Edited By John McNamara on 17/02/2012 14:48:43
                                          #85067
                                          Ketan Swali
                                            @ketanswali79440
                                            Posted by Ketan Swali on 17/02/2012 14:44:17:
                                            Hi All
                                            Cheers
                                            Ketan at ARC.
                                            Any comments Mark Web tech please ?
                                            #85068
                                            Mark Web Tech
                                              @markwebtech33648
                                              Hi John
                                              As I said earlier, we are working on a tweak for image inserting, so that we can cap the size like the previous editor did.
                                              What format does a MediaFire link look like? Could you do me a favour and try pasting one in using the YouTube embed button for me please?
                                              Thanks
                                              M
                                              #85069
                                              Mark Web Tech
                                                @markwebtech33648
                                                Ketan I'm not sure what the problem is here.
                                                M
                                                #85070
                                                John McNamara
                                                  @johnmcnamara74883
                                                  Hi Mark
                                                  Please PM me with an email addy and I will send a screenshot
                                                  Cheers
                                                  John McNamara
                                                    @johnmcnamara74883
                                                    Done!
                                                    #85073
                                                    David Clark 13
                                                      @davidclark13
                                                      Hi Maurice
                                                      What thread is faulty?
                                                      Regards david
