Posted by noel shelley on 19/05/2023 11:20:13:
Interesting ! but with only between 1 and 2 Kw even small amounts of metal will take a while to reach a pouring temp, never the less a novel idea ! There are also plenty of vids of induction melting but again with domestic power limitations it will be slow and stewed metal is like stewed tea, not so good ! For VERY small castings may be. To do an 8Kg melt – NO ! Noel.
Back in the 1970’s we had a 3kW microwave oven which was used for drying samples. Not the best, because nearly dry samples did not absorb much microwave energy! Not the only poor devision when they initially changed form chemical analysis to X-ray fluorescence. They later went back to drying over a hot-plate heater.
However one, or more, of the ‘clever’ shift workers included steel nibs in the samples (on purpose, of course). I can’t remember if they got hot enough to melt, but the ceramic dishes, silica sheets, etc, were certainly annihilated or seriously damaged.
Edited to add that with exceedingly good insulation, there is not actually much heat power needed to melt some metals. It is cumulative!
Edited By not done it yet on 19/05/2023 20:57:45
