I made up a longer topslide for my lathe using Meehanite rectangular block and although I had a good extra 3/16th all over, I did notice that when cut to length, some of the material inside looked slightly darker towards the surfaces, bit like a rectangular stick of rock. When I machines the outer surfaces down, there was no discernible sense of the material near the surface being any harder but you could still definitely see a very slight patchwork of darker material. I can only put this down to cooling rates at point of manufacture and the iron changing it's form slightly as a result. In machining terms, it doesn't appear to have altered the properties of the material to any degree I can notice.
Edited By Chris Trice on 25/04/2012 22:27:57
