Mechanical Lubricator & Check Valve
Home Forums Traction engines Mechanical Lubricator & Check Valve
  • #639449
    Howard Atkins 1
      @howardatkins1
      Hi, l
      Looking for a sketch or drawing showing the internal components and layout of a mechanical lubricator and check valve for my 4" TE.
      There are two o-ring seals, two supporting discs, the ball and spring.
      Are drawings availble showing the O ring size
      The ram is 3/16"
      Howard Atkins 1
        @howardatkins1
        #639452
        Dave Wootton
          @davewootton
          I think from your description above that you might mean the Jim Ewins type lubricator design, a google search using his name should bring something up. Uses a pair of o rings and the output can be designed in by varying the shim washers as opposed to the LBSC type oscillating cylinder design.
          #639455
          duncan webster 1
            @duncanwebster1
            here's a drawing, but 1/8" bore, so you'll need to scale it up. I'd leave the oring section at 1/16" nominal.
            If you google deep enough you might find details, if not I've probably got them somewhere, but take a bit of finding
            Edited By duncan webster on 28/03/2023 19:12:07
          Home Forums Traction engines Topics
