When I started my apprenticeship, one of the training exercises was to be measuring a bearing on the outside, and then using a telescopic gauge and micrometer, until I got the correct dimensions. My last measuring exercise was to measure the bore of a ring gauge , not seeing it's exact size, and then writing down on paper those sizes of the measurements. Then measure a gauge block without seeing it's length and writing down those sizes, all under observation for the test.
It was an exercise well worth doing. In those days we had a temp controlled measuring and inspection room. It taught me 2 things, when dimensions get bigger than 100mm, temp of the part and measuring gear matters. As well as the materials they are made from etc. The other was, when using a telegauge to measure a bore, take two measurements at 45 deg to each other. Otherwise you can not tell if the part is slightly oval or lobed.
Proper bore micrometers in a workshop , will pay for themselves just in the measuring time savings alone in a year, depending on how many and how often a bore is required to be measured etc.
