ME4717 Miscollation
ME4717 Miscollation
Home Forums Model Engineer. ME4717 Miscollation
Viewing 25 posts - 1 through 25 (of 36 total)
  • #645201
    John Abson
      @johnabson65530
      Anyone else’s copy with the pages out of order?
      Presumably to do with the print layout…
      /J
      Edited By SillyOldDuffer on 15/05/2023 11:25:29
      OldMetaller
        @oldmetaller
        I've just had ME 4717 drop through the letterbox and I thought I was still pi$$ed from last night when I opened it- the pages are all jumbled up, in random order. Is anyone else's copy like this, or just mine?
        John.
        #37923
        OldMetaller
          @oldmetaller
          Pages out of order
          #645208
          Roger Vane
            @rogervane67137
            Mine too – and i'm sober.
            #645213
            the artfull-codger
              @theartfull-codger
              Hi, Just received my copy of ME no 4717 & the pages are all mixed up,& wondered why Luker had gone from his Fire Queen to Doug Hewson's B1,anyone else got the same mix up?
              Graham.
              Edited By SillyOldDuffer on 15/05/2023 11:26:24
              #645214
                Been a flurry of new threads reporting this problem that I've consolidated together. Apologies if I messed up and the posts are jumbled or lost!
                Hopper
                  @hopper
                  The printing press and subsequent machinery to cut, fold, collate and staple the magazine would make an interesting article for MEW. Quite a process to behold, and all happening at a million miles an hour. When things go wrong, they can go really wrong! As has obviously happened. Some printer is about to get his derriere kicked.
                  Edited By Hopper on 15/05/2023 12:02:42
                  #645222
                  noel shelley
                    @noelshelley55608
                    ADD ME TO THE LIST ! Noel.
                    #645223
                    KWIL
                      @kwil
                      I simply telephoned Mortons and a new complete copy is in the post.
                      Mine had merely many missing pages and hence was thinner.
                      #645225
                      edintheclouds
                        @edintheclouds
                        Maybe you have to open the staples and collate the pages yourself, all pages seem to be there, much like playing the piano with all the notes but not in right order.
                        Les
                        #645226
                        Michael Johnson 6
                          @michaeljohnson6
                          Here here!. Just taken it all apart, re-ordered and re-stapled. Nice little challenge for a Monday morning!
                          #645229
                          Ady1
                            @ady1
                            So it's all there, but in flat pack format
                            #645232
                              Posted by Michael Johnson 6 on 15/05/2023 14:02:57:
                              Perhaps it's a test to see how many Model Engineers can actually fix things!
                              My copy hasn't arrived yet.
                              sad
                              #645233
                              Clive Foster
                                @clivefoster55965
                                Mine had the centre 10 pages transposed to the beginning and end of the magazine text proper, ie 5 pages at each end.
                                Fixed by using paper clips to hold the two transposed sections together, removing the old staples, putting things in order and re-stapling. Would have been easier I had a long reach stapler but one of mile flips out to 180° so I could drive them through into a drawing pad then flip over to hand bend the ends. Good enuf for government work.
                                Edited By Clive Foster on 15/05/2023 15:23:57
                                #645235
                                Model Engineer Editor
                                  @modelengineereditor
                                  ME4717 Miscollation
                                  If you are a subscriber to Model Engineer and have just received your latest issue you may find that the pages are miscollated. They are all there but not necessarily in the right order. This was caused by a printer error. The issue is currently being reprinted and subscribers should receive a replacement copy within the next few days.
                                  Alternatively, in the spirit of one aspect of model engineering, you could consider the issue as a kit and rearrange the pages yourself!
                                  We apologise for the inconvenience but be assured that we are 'on the case'.
                                  Edited By JasonB on 15/05/2023 16:55:07
                                  Edited By JasonB on 15/05/2023 16:56:13
                                  #645236
                                  John Haine
                                    @johnhaine32865
                                    Thanks Martin. Maybe there should be a small prize for the most interesting and appropriate re-collation?
                                    Edited By JasonB on 15/05/2023 16:55:52
                                    #645245
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi, yes mine came this morning, but I've been busy calibrating my A0 plotter after changing the carriage belt last week, and then finding out it needed a printhead replacement which I had to put in first. I may as well wait till a replacement ME comes, as my MEW 328 also came, which is all in order, so I can read that.
                                      Regards Nick.
                                      #645256
                                      Grindstone Cowboy
                                        @grindstonecowboy
                                        Slightly off-topic, but I once bought an American car magazine and found some of the pages were missing. Returned it to the newsagent, who gave me the next copy off the shelf – that one was complete plus it had all the missing pages from the first. Actually surprised it doesn't happen more often with the speed that those printing presses run at.
                                        Rob
                                        #645283
                                        DMB
                                          @dmb
                                          Paper handling machinery does go very fast but unfortunately faster = bigger ballsup! I was shown a machine with lots of pipes and suckers to fold and assemble Invoices and statements then fold a flat envelope around them and seal it. That was about 50 years ago, when they had a typing pool to retype the buggered Invs and Statements. That machine was fast but probably slow compared with today's machinery.
                                          duncan webster 1
                                            @duncanwebster1
                                            I just took out the staples, shuffled the pages and put the staples back. It only took a few minutes. We are after all supposed to be engineers. To quote Forest Gump "shit happens". I'd ampily that, live with it.
                                            #645309
                                              My copy still hasn't arrived, but just in case it's faulty, I'm building a Magazine Re-assembler. Sixteen Arduinos programmed to manage a repurposed electric toaster. Very promising so far, only takes 11 hours to disassemble and incinerate a perfect magazine. Under budget too, £800 well-spent…
                                              smiley
                                              Edited By SillyOldDuffer on 16/05/2023 08:35:00
                                              #645311
                                                Dave you can get them ready made and cheaper from Vevgoodexpresssmile p
                                                Still waiting for postie.
                                                #645313
                                                Grindstone Cowboy
                                                  @grindstonecowboy
                                                  Posted by JasonB on 16/05/2023 08:38:18:
                                                  Alibangvor also have them. yes
                                                  Rob
                                                  #645322
                                                  Clive Foster
                                                    @clivefoster55965
                                                    Maybe it would have been worth getting that long reach stapler for £5 last year even though I only thought I might find it handy.
                                                    By my standards 12 months from "Good price, I'll get one just in case I ever need one." is positively supersonic.
                                                    Longest wait from "handy buy" to "actually" so far is about 25 years. Some things still waiting in the cupboard after over 30!
                                                    #645324
                                                    Hopper
                                                      @hopper
                                                      Posted by Clive Foster on 16/05/2023 09:13:36:
                                                      And throw it away after 30 years, you will desperately need it for sure after 30 years and 3 days.
                                                    Home Forums Model Engineer. Topics
