ME Vertical Boiler
ME Vertical Boiler
Home Forums Model Engineer. ME Vertical Boiler
  • #409081
    martin ranson 2
      @martinranson2
      In the latest issue of Model Engineer, issue 4612, Martin Gearing is running a series concerning the ME vertical boiler … he mentions the use of a thread sealant for use with propane gas … please could Martin (or anyone else ) tell us the name of a suitable product ?? … hopefully I can buy it at the local plumbers/builders merchants.
      martin
      martin ranson 2
        @martinranson2
        Thread sealant
        #409092
          A big pot of Boss White from B&Q will set you back £4. Good enough for LBSC…
          "This jointing compound from Boss is suitable for use with hot and cold water (non-potable duties) natural gas and low pressure steam up to 7 bar pressure and 200°c. "
          http://www.diy.com/departments/boss-jointing-compound-400-g
          Edited By Neil Wyatt on 13/05/2019 15:09:30
          #409629
          martin ranson 2
            @martinranson2
            To Neil please … I will try to send another thank you for the information you sent …my reply appeared on the screen as edit post … it has now disappeared … I was just checking to see if anyone else had answered … I have just been to our local B and Q to buy some … they do not list it any more … thank you again for the information … I will keep hunting.
            martin
            #409630
              Have you got a Toolstation near you or a traditional plumbers merchants, both should have it or another similar make like Fernox or Laco which your local Screwfix should have
              #409662
                yes
              Home Forums Model Engineer. Topics
