ME Beam Engine – Water Pump Connections
Home Forums Beginners questions ME Beam Engine – Water Pump Connections
  • #516443
    Malcolm Farrant
      @malcolmfarrant93389
      I am at a loss to understand the two Pipe connections on the Water Pump.
      One comes from the underside of the casting, and the other from the top. Both then go thru the aluminium base-plate.
      However I can find nothing that tells me what then happens to them. Obviously they must connect to something, but what ?.
      No doubt I am being stupid, but PLEASE can someone enlighten me.
      In anticipation many thanks, and my hopes that 2021 will be a better year for us all.
      Best wishes Malcolm Farrant (Roskrow)
      Malcolm Farrant
        #516444
        Former Member
          @formermember12892
          #516445
          Paul Lousick
            @paullousick59116
            Which issue of ME is beam engine in ??
            Paul
            #516449
              As said if you are running on steam then connect the bottom to water supply and top to boiler clack. If you are on air or separate feed pump to boiler then just treat the engines own pump as decorative.
              #516450
              Ian Hewson
                @ianhewson99641
                Or you could add a baked bean tin and pump water too and fro, as in my engine.
                Had to do a screenshot as video of engine running was too large.
                Ian
                Edited By Ian Hewson on 31/12/2020 12:32:16
                #516451
                Former Member
                  @formermember12892
                  #516455
                  Paul Lousick
                    @paullousick59116
                    Thanks, it looks like a good project to build. Unfortulate that the archive only goes back to 187, not as far as 121
                    Paul
                    #516664
                    Malcolm Farrant
                      The artic;esstarted in issue 4603 and then continued every2 weeks until 4643.
                      Hope that helps. The castings are available from Reves
                      #516677
                      Malcolm Farrant
                        As usual many many thanks for the helpful answers
                        Best wishes
                        Malcolm
                        #516686
                        Former Member
                          @formermember12892
                          #516696
                            Posted by br on 01/01/2021 12:25:51:
                            I did put up all the info and then managed to duplicate it so altered the duplicated one to say DUPLICATE REMOVED
                            I see the mods have managed to leave that one and deleted the reply that had all the info in which Paul thanked me for.
                            br
                            Sorry br, wasn't me that deleted the right one, but I just zapped the dud… I can't retrieve the lost post because pressing delete is permanent.
                            Former Member
                              @formermember12892
                              #516703
                                Your original is still there at 12.45 with the Volume numbers, Dave has deleted the one that said duplicate which was directly after it. Unless you had put more info in the one that you then changed to duplicate.
                                The ME Beam has been covered several times, the one in vol 122 gives 4 page sover to teh pump though it is fabricated rather than made from castings.
