ME Beam Engine valves
Home Forums Beginners questions ME Beam Engine valves
  • #10619
    Malcolm Farrant
      @malcolmfarrant93389
      Malcolm Farrant
        I have trief to make the necessary STEAM COCK and THROTTLE VALVE, but without success.
        The ME article implies these two items can be prchased, but I am ubable to find a suitale source.
        Can anyone give me a clue as to who to use ?
        Your assistace is appreciated
        Thank you
        Malcolm Farrant (Roskrow)
        #518646
        Oldiron
          @oldiron
          Hi this looks like a duplicate post. Could be a bit of a PITA. Might be best to take one down.
          regards
          #518690
            No, two completely different questions.
            Malcom from looking at the article I think it was suggested that only the shut off valve could be substituted for a commercial globe valve. Most of the ME suppliers will have these listed under boiler fittings for example here and here though usually with threaded ends for nutted unions so you will have to do a bit of modification to be able to screw them into the governor valve or to join with flanges though there is no real reason the shut off has to be right on the engine and could really be anywhere in the supply line or even on the boiler or compressor.
            If you want a flanged valve then you will need to look a bit further afield
            You may be able to modify a water valve for the governor as these are 1/4 turn valves
