ME beam engine
ME beam engine
Home Forums Stationary engines ME beam engine
Viewing 25 posts - 1 through 25 (of 25 total)
  • #531491
    Jager
      @jager
      Good evening,
      I am given to consideration to attempt building an ME beam engine and see that there are a number of firms producing casting kits. I am aware of Stuart Models producing a set of castings for a similar model, but find their prices would bring a tear to a glass eye.
      I wonder if there are any members here who have recent experience of available kits and who are able to give constructive criticism of potential suppliers to help this rank amateur avoid making the wrong decision.
      Jager
        @jager
        #531494
          The Stuart offerings are either the "beam" which is a much simplified engine that is a little smaller than the ME Beam or the "Major beam" which is to a similar level of detail to the ME but considerably larger hence the high costs.
          There are only two sources of castings for the "ME Beam" that I can think of which are Reeves and Brunell, If I were in the market for a set of these castings then I would go 100% with Reeves.
          There is also the option to make it without castings or to buy just a few such as Flywheel and cylinder and then fabricate or cut the rest from solid which would be the way I would tend to go.
          #531499
          Ian Hewson
            @ianhewson99641
            Bought my beam engine castings from Reeves in 2015, nice quality, would recommend them.Makes a nice engine.
            #531596
            Jager
              @jager
              Bill & Jason,
              Many thanks for your input.
              I am convinced to go with Reeves.
              Wish me luck!
              David
              #531599
              Russell Eberhardt
                @russelleberhardt48058
                +1 for reeves. I bought the casting set for the beam engine "Mary" many years ago and found the castings to be good quality.
                Russell
                #532080
                Jager
                  @jager
                  Gents,
                  Many thanks for your advice.
                  I have obtained a set of castings for the ME beam engine and realise a build guide would greatly assist me.
                  Is there a means to obtain the series if articles which were published in MEW, Ibelieve in 2019?
                  David.
                  #532088
                    It was in ME.
                    Digital backissues can be bought from Pocketmags
                    Some paper back issues by clicking the link on the black line at the top of the page
                    Or it may work out cheaper to take out a years digital subscription and access the articles from the archive here.
                    E-bay etc will probably provide a volume or two that contain the older original build series
                    Edited By JasonB on 06/03/2021 13:05:10
                    #532102
                    Jager
                      @jager
                      Thanks Jason,
                      Am I correct in thinking that a digital subscription to ME is what you mean? Or upping my paper subscription to MEW as your 4th para.?
                      David
                      #532150
                        No you would need a full digital subscription to ME rather than just paying the extra to include digital to your existing MEW print subs as you only get access to one mag's archive per digital subscrption.
                        #532153
                        Jager
                          @jager
                          Posted by JasonB on 06/03/2021 16:45:28:
                          Thanks.
                          #533000
                          Michael Baloh
                            @michaelbaloh57611
                            Hello,
                            I have wanted to build a ME Beam for a number of years singe learning machining in school. I even went as far as buying the prints and getting photo copies of the EXACTUS articles from 1959.
                            Anyhow, I finally have a home shop and wanted to buy the castings. I am concerned about Reeves Casting quality based on some online comments (always dubious) It's even more of a concern since I live in the United States and dealing with replacements would be painful.
                            Jager, you mention getting the castings recently. Are they ok? Symmetrically cast?
                            What is the forum consensus on this point? My only alternative is to go with the Major Beam from stuart. That option is expensive, but also, I would need some help from my friend with the 19" lathe to finish the flywheel.
                            Any advice from the forum would be appreciated.
                            Thanks,
                            Michael.
                            #533489
                              Michael as nobody else has come back to you these are my thoughts. As mentioned above Reeves are a far safer bet than other sources of the castings and at least you will get the castings. I've not bought much in the way of castings from Reeves for a number of years as they don't do anything I want to build but have had a few flywheel castings in recent times that have been perfectly acceptable.
                              As I mentioned above there is a lot of the engine that could either be fabricated or cut from solid rather than use the available castings. Having had another look through the old articles I would say the beam and flywheel would present the most difficulty to make from scratch, the cylinder is not too difficult and the bed casting can simply be done from a sheet or two of aluminium adding the bolt hole bosses around the side from separate parts. So one option would be just to buy these two parts from reeves and at least then if they were unusable you would not be a lot out of pocket if replacements were uneconomic. I have not heard of problems with these two castings so fingers crossed.
                              #533556
                              Jager
                                @jager
                                Michael, I apologise for my tardy response but this is my fourth attempt – each time I hit the button for ADD POSTING everything deletes.
                                I now have the castings and have begun work. Thus far I have machined the baseplate and the main column and all seem acceptable.
                                If you search on line BUILDING THE ME BEAM ENGINE you should find a vid by 'engineeringmodeller'. He has some good vid, lots of pics of his build and somewhere amongst his stuff is a narrative detailing errors he found in the drawings.
                                I hope this is of some help.
                                David
                                #533847
                                Michael Baloh
                                  @michaelbaloh57611
                                  Thanks everyone for your response. I contacted Reeves by email and they explained their policies for defective castings. They also explained their procedure for checking them one they arrive from the foundry. I also called and spoke with them. So, after hearing your responses and having heard from Reeves, I feel fairly comfortable ordering from them.
                                  I also reviewed engineeringmodeller videos and his site with build notes and pictures. I found that quite interesting.
                                  Now, the main question is weather to order the Major or the ME. Since, Stuart and Reeves are waiting for parts from the foundry I have some time to scratch my head about that which one to buy. It would be interesting to see the two side by side to get a feel for them. I have heard the Major is just to imposing an engine and too big for some.
                                  Again, thanks for the feedback.
                                  Michael.
                                  #533849
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by JasonB on 06/03/2021 13:04:11:
                                    But you only get to see the ones you've paid for since Flash player died, unless I'm missing something
                                    #533853
                                    Former Member
                                      @formermember12892
                                      #533864
                                        Posted by duncan webster on 14/03/2021 14:34:54:
                                        The ME Build is quite recent so will be in HTML and all issues since the change, wait a while and the old Flash ones will also be updated.
                                        #533866
                                          Michael, quite a good build thread of the Major beam here, I think a lot of people don't do it as the flywheel is too bug for their lathe.
                                          #594906
                                          Jager
                                            @jager
                                            12 months down the line and the ME Beam Engine is ready for stripdown, painting and final attention to detail such as adjusting gibs and cotters to length, final stud lengths etc..
                                            Perhaps the next project will be a suitable boiler to steam it.20220416_183532.jpg
                                            #594907
                                            Jager
                                              @jager
                                              #594921
                                                That looks good, have you tested it on air? I tend to test mine before painting as if anything needs taking apart there is less risk of chipping the paint.
                                                #594929
                                                David George 1
                                                  @davidgeorge1
                                                  Nice work. Glad to see work that is in progress as sometimes prodjects disappear and I wonder how they got on. Looking forward to see it after the finnishing process and running.
                                                  David
                                                  #594930
                                                  RMA
                                                    @rma
                                                    I think I'm with Jason on this one. I have a set of Reeves castings for this engine, bought several years ago and put aside until now. The state of most of the castings are terrible, more metal to fettle off than in the actual work piece in many cases, and the aluminium baseplate is banana shaped!
                                                    If I was starting again, I would make most parts from solid and a lot cheaper too! I was made aware by friends who have completed the engine, that there are several mistakes on the drawings.
                                                    #594963
                                                    Jager
                                                      @jager
                                                      Thanks for your kind words. Yes Jason it runs ok on air and apart from minor adjustments to be made during final assembly I am hoping that once the bearings and gears are all bedded-in it will be capable of running at a realistically sedate speed.
                                                      David, I resisted the temptation to divert to other projects and instead determined to see this one through. Model engineering is something I came to late in life when other pursuits were becoming difficult. Fortunately I seem to have retained a vestage of skills learned many years ago and their current resurrerection is the cause of much personal pleasure. I would dearly like to build a triple expansion engine but fear time is against me so I shall curb my enthusiasm and stick with smaller things.
                                                      RMA, I didn't find the Reeves castings too bad although the bedplate did need truing, some items were badly chilled and the entablature is dreadful as may be seen in the photo; I will remake this in mild steel. What I did find annoying was the obvious missmatching of the journal bosses on the beam. A conscientious supplier would have a new pattern made, as well as correcting the drawings in respect of the Watts parallel linkage interference and the valve gear errors caused by the change of steam chest.
                                                    Home Forums Stationary engines Topics
