ME 4415 – Darjeeling B Class
Home Forums Drawing Errors and Corrections ME 4415 – Darjeeling B Class
  • #76649
    Steambuff
      @steambuff
      Can someone please confirm the dimensions on the Smokebox Pipe Plate drawing.
      According to the drawing there is a 8BA clearance hole between the 5/16″ and the 1/4″ holes.
      The center to center dimension between the 1/4″ and 8BA hole is give as 11/64″ …. now if my maths is correct this only leaves approx 1/256″ between the two holes. (No room for the head of a bolt/screw/rivet)
      8BA clearance = 2.2mm = 0.086″ =11/128 … (radius = 11/256″)
      11/64″ – 1/8″ (radius of 1/4″ hole) = 3/64″ = 12/256″
      12/256″ – 11/256″ = 1/256″ (approx 4 thou)
      Is this correct …. seems a bit too close to me.
      (On the drawing it appeas that it should be approx 5/16″ – Mid point between the 2 centers)
      Steambuff
        @steambuff
        Smokebox Pipe Plate dimension
        #76691
        Donald Mitchell
          @donaldmitchell68891
          Hi Engineers,
          I have spoken to Raymond this morning and he confirms that he has no idea where the 11/64 dimension has come from; the 8BA hole is simply placed mid-way between the 1/4 and the 5/16 holes where it will be very happy.
          Donald Mitchell
          Bonnie Scotland
          #76692
          Steambuff
            @steambuff
            Thanks Donald/Ray.
            I have just checked the drawings, that I purchased from Blackgates .. and it is there as well.
