Mazak castings
Mazak castings
Home Forums Workshop Techniques Mazak castings
  • #89046
    mike T
      @miket56243
      Mazak (Zamak) or monkey metal is used extensively in the auto and other industries to make small accurate castings, including spin casting into silicone moulds.
      Does anyone know where I can buy a small quantity of Mazak (Zamak) ingots? I do not want to start with scrap material. I will probably make enough of that anyway.
      Thanks
      mike T
        @miket56243
        monkey metal
        #89049
          Mike,
          I don't think they sell Mazak as such … but this is a very good place to look for an alternative:
          http://www.tiranti.co.uk/subdivision_product_list.asp?Content=White+Metal+%2F+Tin+Alloys&Subcategory=63&Subdivision=
          Edited By Michael Gilligan on 13/04/2012 19:02:18
          #89052
          Andrew Binning
            @andrewbinning37010
            Try Alec Tiranti, they supply the all sorts of moulding/casting supplies and while they do not appear to supply metal as such, they may know where to go. http://www.tiranti.co.uk
            They used to advertise regularly in ME and I had to search back numbers to find them.
            Hope this helps.
            #89056
              Andrew Tranti's do quite a few metals for casting try this section of their site but I think most are lead/tin alloys.
              J
              #89070
              mike T
                @miket56243
                Hello John,
                I am not sure that is the answer. Mazac (Zamak) is an alloy of Al, Cu, Mg, Pb, Cd, Sn, Fe,with a trace of Ni and Si. As an alloy, Zamac 2 melts at about 385 degrees C which can be reached electrically. So if I could find ingots of all the components, instead of a ingot of the Mazac, I would not be able to melt some of the elements and some i would not want to touch.
                No, I will continue my search for some Mazac (Zamac) ingots. The problem seems to be that Zinc alloy casting is another skill that has been lost in Great Britain
                #89071
                Chris Trice
                  @christrice43267
                  I know you said you didn't want to go the scrap route but old diecast toy cars like Dinky and Matchbox were cast in Mazak.
                  #89073
                    These people sell ingots but whether they will supply small amounts is another thing, maybe they could point you in the right direction though.
                    http://www.brockmetal.com/page.asp?node=100
                    #89110
                    Russell Eberhardt
                      @russelleberhardt48058
                      Posted by mike T on 14/04/2012 00:16:30:
                      This is not really true. There are die casting companies all over the place using both aluminium and zinc alloys. Do a Google search for "zinc die casting" in your area. You may well be able to scrounge some scrap castings.
                      Russell.
                      #89158
                      mike T
                        @miket56243
                        Hello Jason and Russell,
                        Thanks for taking the time to reply.
                        Brockmetals have a minimum order quantity of 1000Kg. That should last a while!!!!
                        The Thompson Local Directory was delivered yesterday, so I will try to contact the local??? die casters. Fingers crossed.
