Material to use ?
Material to use ?
Home Forums Beginners questions Material to use ?
  • #54275
    michael bird
      @michaelbird72946
      Hi,
      Please advise – can I use EN1A F/C steel for the shafts on my 1.1/2″ Allchin. One  shaft of course has splines, however, it will be more a thing of beauty (I hope) than a work horse.  Your comments please
      Bob.
      michael bird
        @michaelbird72946
        #54276
          Should be fine on an engine of that size particularly if its not getting a lot of use.
          Jason
          #54436
          Lawrie Alush-Jaggs
            @lawriealush-jaggs50843
            Hi Michael
            I was reading this the other night, it should be right up your alley
            #54438
              But you won’t be surface grinding or heat treating any of the shafts so it’s all a bit irrelevant and hopefully you won’t be running at several thousand rpm like a CNC machine would!!
              Jason
