Material Suppliers
Material Suppliers
Home Forums Beginners questions Material Suppliers
Viewing 23 posts - 1 through 23 (of 23 total)
  • #41484
    ChrisH
      @chrish
      Hi, does anyone know of a good metal stockholder in the Yeovil/Dorchester/Taunton area that will supplier private customers – as opposed to trade – with modest amounts of stuff at a reasonable rate please?
      ChrisH
        @chrish
        #41487
        David Clark 13
          @davidclark13
          Hi There
          If still trading, Dorset Metals.
          I think they are at Ferndown Industrial Estate Dorset.
          regards David
          Edited By David Clark 1 on 18/05/2009 15:17:51
          #41492
          keithmart
            @keithmart
            Hi
            I often purchase from Metal Supermarket. There is one locally in Leeds, but I think your nearest would be Southampton.
            Worth a look on the web as they are very helpfull.
            Keith
            Leeds UK
            #41493
            Circlip
              @circlip
              Oft forgotten but worth a scan, get yer local copy of Thompsons and look for Fabrications and Engineering shops in the area and ask if you can go “Skip Surfing”  Local Industrial type scrapyards are good too but you need to set up a repartee with operators, and DON’T go in a suit.
                    Regards   Ian.
              #41504
              Peter Williams 1
                @peterwilliams1
                You could try EKP Supplies in Barnstable, I’ve used them for all kinds of engineering supplies including metal. They are prompt and reasonably priced.
                Their catalogue is online at http://www.ekp.supplies.btinternet.co.uk
                Peter
                #41537
                ChrisH
                  @chrish
                  Hi Guys,
                  Thanks for the replys – I will follow them up.
                  A question for keithmart really – the Metal Supermarket, is that a place where you can browse around to find what you need, or has it just a counter where you are supposed to know what you require, like a builders merchants trade counter where you are invariably left feeling inadequate trying to describe what you want without knowing the trade names!
                  Regards, Chris
                  PS.  Am impressed how this website is moving on in only the few days I have been logging on……………….
                  #41540
                  keithmart
                    @keithmart
                    Hi
                    It Depends, I tend to have a fair idea of what I want, most of the time
                    But if you ask for say “I need some steel to turn in a lathe” they will usually find something suitable.
                    #41555
                    Funnyturn
                      @funnyturn
                      If you want to buy online I can recommend:
                      Prompt and friendly service.
                      #41560
                      Sandy Morton
                        @sandymorton10620
                        My local Metal Supermarket lets me browse and then tells me whether I have picked the correct metal or not!  Only drawback is that they have a £10 minimum order which for a typical Scot is an awful lot of money.
                        #41608
                        Ian Hart
                          @ianhart94481
                          Hello
                          Can anyone recommend a supplier of small amounts of aluminium and brass in the Sheffield/Doncaster area?
                          Ian Hart
                          #41609
                          David Clark 13
                            @davidclark13
                            Hi There
                            There are plenty of people selling small quantities of metal on Ebay.
                            regards David
                            Edited By David Clark 1 on 25/05/2009 08:44:54
                            #41610
                            Sandy Morton
                              @sandymorton10620
                              Pedant on.  The email notification which I got about the previous message on this forum has slling instead of selling.  I would assume that it was an automagic copy of your posting so might be worth a look?
                              #41614
                              Ian Hart
                                @ianhart94481
                                David
                                Thanks, I was trying to avoid postage charges if there was somewhere local that I could use if out and about.
                                Ian Hart
                                #41725
                                mgj
                                  @mgj
                                  Chris – H I live in Kings Stag up near Sturminster. I bought 220M07 free cutting mild from  Pulham Steels.
                                  There is also Dyfed Steels up in Shaftesbury.
                                  If you e-mail me we could put an order together – if they want to sell in 3 meter standard lengths.
                                  Somdor engineering on the Henstridge Trading Estate have a very healthy scrap bin. A  Mr Ford owns it and is very helpful to model engineers. (Rolled the smokebox for my TE perfectly and for peanuts. Welded up a tuned pipe manifold in ali for a model aircraft ) They don’t have much freecutting mild, but could help with more normal engineering grades, especialy in bigger sections/dias/
                                  #41815
                                  Geoff Theasby
                                    @geofftheasby
                                    Ian Hart,
                                    I have obtained brass and aluminium from a couple of non-ferrous scrapyards in Attercliffe, Sheffield.   I can’t remember their names, but the Yellow Pages should show them.
                                    Geoff
                                    Edited By Geoff Theasby on 11/06/2009 16:04:11
                                    #41816
                                    Niloch
                                      @niloch
                                      I’ve bought aluminium offcuts: plate, bar and tube from the ebay shop run by
                                      They sell ferrous as well as non-ferrous and are usually even more helpful to personal callers with cash!
                                      Usual disclaimer.
                                      #41850
                                      ChrisH
                                        @chrish
                                        I’ve tried to find ringwood precision on ebay shops – but with conspicuous lack of success.  I can find their own website, but not ebay shop.  What do they go under on ebay?
                                        Chris
                                        #41851
                                        David Clark 13
                                          @davidclark13
                                          Hi There
                                          Try searching for
                                          ukroy
                                          regards David
                                          #41852
                                          Niloch
                                            @niloch
                                            David Clark 1 above is quite right but if you’re still having difficulty click here
                                            #41855
                                            mgj
                                              @mgj
                                              Yes but…… some of these prices people are advertising you’d be better off buying the full 3 metres of a free cutting mild like 220M03/EN1A , cutting off the couple of foot you want and chucking the rest away!
                                              Slightly different with non ferrous.
                                              Incidentally there is a big metal wholesalers in Bristol if anyone wanted to do the Yellow Pages thing. They are supplying a lot of retailers in the SW. They only sell in 3m lengths, but that would not be a problem for a club or something to put an order in. They certainly do 220M03 in imperial sizes, as well as the standard engineering grades.
                                              #41857
                                              David Clark 13
                                                @davidclark13
                                                H There
                                                If buying full lengths, beware the neighbours.
                                                Some tolerate model engineers.
                                                If lorries with long lengths of steel start turning up,
                                                they might report you to the council for running a business.
                                                regards David
                                                #41859
                                                mgj
                                                  @mgj
                                                  With respect – no.
                                                  Firstly if you are not running a business you have no problem. Provided you your activity doesn’t constitute a nuisance (noise, hazards like welding flash, paint spray).
                                                  Second the occasional truck turning up is no worse than if getting bricks, timber or tiles delivered for a bit of serious diy. Its only if things get unreasonable…….
                                                  In fact all I do is buy the 3 metre length, and ask the man to guillotine it into 1m lengths  They don’t mind chopping it up – its the spare offcuts they can’t sell they don’t want lying around. They can quillotine up to 1 1/2″ dia. On with the gloves and all onto a blanket in the boot of the Fiesta. OK, you lose an inch or so either side of the cut, because of crushing, but if you have 3m of it, 4 inches is not an issue – providing one has ones parting off sorted. Mandraulically hacksawing and facing might be!!
                                                  The break poimt is about 1 1/4″ dia. After that its just easier because of transport and actual usage, to buy a metre for £20 off a supplier – its probably a lifetime buy anyway, or it is for me.
                                                  I don’t suppose that many model engineers use significant quantities of steel over the 1/14-1 1/2″ mark?
