material choice
material choice
Home Forums Materials material choice
  • #650277
    Chris Goodwill
      @chrisgoodwill78822
      Hi
      I need to replace a vice handle, the current one is bent, too thin, end caps don't fit well, rusty ect. I have been looking on ebay and stainless steel is cheap. It's going to be 16mm dia about 30cm long. Anybody think of a reason why 304 stainless would be a bad choice for a vice handle?
      Chris Goodwill
        @chrisgoodwill78822
        #650280
          Stainless 304 wouldn't be my first choice. Mainly because it work-hardens, requiring sharp-tools that are kept cutting by the operator at all times. Rubbing a tool on 304 hardens the steel and blunts the tool pronto.
          Cutting work-hardening stainless isn't horrifically difficult, but it's risky enough that I avoid 304. Also, stainless is unlikely to be cheaper than mild-steel.
          Bear in mind too that the existing thin bendy handle may be deliberate. It's because vice handles are usually sized to bend just before the vice breaks…
          Tony Pratt 1
            @tonypratt1
            Just use mild steel if you can get away with it, back in the day when we didn't buy everything from China vice handles were normally a one piece forging.
            Tony
            #650286
            Bazyle
              @bazyle
              If you think 16mm mild steel is going to bend in use shoot the monkey using it before they do serious damage to something important.
              #650288
              Chris Goodwill
                @chrisgoodwill78822
                OK, so this doesn't need to be case hardened or anything special, just basic mild steel.
                That will making it a lot easier..
                Thanks
                #650290
                jimmy b
                  @jimmyb
                  I milled a hex on the shaft and 3D printed a handle.
                  Works well.
                  Jim
                  #650301
                  not done it yet
                    @notdoneityet
                    Posted by SillyOldDuffer on 28/06/2023 15:45:47:
                    Generally, the handle is made to a suitable length, such that the vise cannot be over-strained. It is often a length of pipe that causes damage. This is not a large vise, if the handle is going to be only about 30cm long.
                    Handle ends can be added by plug welding, screwed/bolted on with loctite thread sealant, shrink fitted, or any other means to hand.
                    Edited By not done it yet on 28/06/2023 19:37:55
                    #650303
                    Anonymous
                      Posted by Chris Goodwill on 28/06/2023 15:09:37:
                      …a reason why 304 stainless would be a bad choice…
                      It's a female dog when turning. smile
                      #650306
                        Posted by Tony Pratt 1 on 28/06/2023 16:44:47:
                        Tony
                        Very interesting, Tony
                        I am not doubting your word, but I’m intrigued to know how a one-piece forging would be fitted to the vice-screw.
                        … was it somehow forged in-situ ?
                        Don’t think I have ever seen one.
                        David George 1
                          @davidgeorge1
                          Have a look on here.
                          https://brooksforgings.co.uk/processes/upset-forging
                          First forge one end clean up with wire brush then heat bar fit through screw end, ( which was also forged then drilled ) and forge the second end in situ and wire brush for finnish.
                          David
                          #650415
                            Thanks for that, David yes
                            Much appreciated
                            Edit: __ the merits of doing it that way are obvious, but I would imagine that handling the finished parts was troublesome.
                            Edited By Michael Gilligan on 30/06/2023 07:28:44
                            #650458
                            Nigel McBurney 1
                              @nigelmcburney1
                              Stainless steel does tend to bind when used as a sliding handle,I have a Record no 23 6 inch vice bought cheap at a sale,handle is 5/8 dia and is bent ,abuse by previous owners, I would recomend tough en 16 or more readily available 5/8 silver steel as it sold in 13 inch lengths ideal for your job, 16 mm may be cheaper and is only about 5 thou larger in dia,it will pay to get tough material as there always comes time when a bit of heave ho with a length of pipe on the handle is required.
                              #650462
                              Georgineer
                                @georgineer
                                Posted by Andrew Johnston on 28/06/2023 19:59:43:
                                Lends a whole new aspect to turning between centres using a dog…
                                George
                                #650470
                                Tony Pratt 1
                                  @tonypratt1
                                  Posted by Michael Gilligan on 28/06/2023 20:38:12:
                                  Tony
                                  Jeez Michael, are we not talking about a milling vice with removable handle, I had it in my head that we were? Recovering from a nasty bout of Covid so not 'with it' atm. Reading the OP yes it looks like a bench vice.
                                  Tony
                                  Edited By Tony Pratt 1 on 30/06/2023 14:30:26
                                  #650522
                                    Thanks Tony … and best wishes for a speedy recovery.
                                    Nigel Graham 2
                                      @nigelgraham2
                                      Vice handles are sized for the grip needed and the likely force exerted by hand – they should not be subject to abuse like "extension" tubes or hammers! If you feel needing resort to that sort of cruelty, think again about the work itself.
                                      A 5/8" (16mm) diameter mild-steel (EN3) handle only a foot long will not bend if you use the vice properly; but if not convinced use a machinable grade of higher-tensile steel (E.g. EN8 ).
                                      You can fit the end-caps by screwing them on, or as press-fit, then the ends peened and cleaned up. The end-caps are only there to stop the handle from falling out. They are not part of the function.
                                      #650542
                                      duncan webster 1
                                        @duncanwebster1
                                        A handle made to the above dimensions from black EN3 will take at least 60lb before it starts to bend, but if you use bright drawn, it will take quite a bit more. I reckon that enough for most people, no need for expensive materials
                                        #650543
                                        Nick Wheeler
                                          @nickwheeler
                                          Posted by Nigel Graham 2 on 30/06/2023 21:17:45:
                                          You could even move into the twentieth century and Loctite them on.
                                        Home Forums Materials Topics
