Hi Chris
Justin case you have no marking out kit, you can still mark the boiler sides at 180 or 90 degrees easily.
Take a strip of heavy paper and wrap it around the boiler. mark a point where the strips overlap, with a fine width pen or pencil. remove the strip, and for 180 degree marks fold it half with the end of the strip and the pen mark lined up. Mark the fold line also. If you now wrap this around the boiler, you have marks at exactly 180 deg apart, so you can centre punch or scribe short line marks on the tube. To scribe lines along these marks all along the tube, lay a piece of known straight angle stock any size on the tube open side of the vee down, that is two edges of the legs of the angle touching the tube. Line up the edge to your mark and scribe away.
For 90 degree marks (ie chimney line vs boiler side lines) fold the strip twice in half and make 4 marks instead of two.
If you are careful and clever about the strip folding you can use this method for any number of divisions theoretically.
With care this method can allow markups accurate to +/- about .010″ in my experince depending on the stretchiness and tension of the paper.
Hope it helps, JD
