Marking out
Marking out
Home Forums Beginners questions Marking out
  • #54859
    Dismaldunc
      @dismaldunc
      Hi Folks, many moons ago when I was at school we used some rapid drying blue stuff to mark out on steel etc, I have no idea what it was called and would like to buy some. I tried “micrometer blue” but that stays sticky and smudges (which I now understand is its function).
      I seem to remember we removed it from the work with meths
      So your advise/help would be much appreciated
      Duncan
      Dismaldunc
        @dismaldunc
        Whats that blue stuff called:-)
        #54860
        Tony Simons
          @tonysimons69671
          Hi
          It is called Marking Blue, or layout blue. It is essentially Prussian blue mixed with meths.
          #54862
          Dismaldunc
            @dismaldunc
            Thanks  Tony, shall now go and google for some!
            #54863
              As said and you should be able to get a small bottle from most of the model engineering suppliers.
              But make sure you do not buy engineers blue which comes in a small flat tin, this is a thick paste use to test the fit of parts.
              A large permanent marker pen can also be used but I find it comes off quicker.
              Jason
              #54864
              Keith Long
                @keithlong89920
                Easiest is a broad felt tip marker, cover the metal and scribe the lines through that.
                Keith
                #54865
                Niloch
                  @niloch
                  You have already been given the essential information but you may well be interested in this thread which attracted 32 posts from early May until a couple of weeks ago.
                  #54866
                  Dismaldunc
                    @dismaldunc
                    thanks again chaps, the post suggested by Niloch was interesting, think I will give the big fat marker a go
                    #55218
                    the artfull-codger
                      @theartfull-codger
                      there’s two types of marking blue [I have both] there’s the translucent type for marking bright metals & also the opaque type for marking black bar etc,I like the idea of dipping a felt tip into marking blue, you get the best of both worlds!!
                      #55247
                      John Wood1
                        @johnwood1
                        Marking out blue or Layout blue is available from (among others) Chronos http://www.chronos.ltd.uk/  It is easily removed with methylated spirit.  I put it on with a small brush and a small amount will probably last you for years.
                        Axel Bentell
                          @axelbentell
                          Did anyone ever use Copper Sulfate as recomended by L.H. Sparey?
                          #55295
                          Ian S C
                            @iansc
                            Axel, look at the other thread mentioned by Nilock. Something aboul boiling cabbages twice. Ian S C
