I have recently re-read The Harris book on steam engines and at the last chapter he mentions a full size marine steam engine which he says was in the Engineer magazine and he give numbers of the issue 20-6-13 which I presume is the date issue.
It is a twin two cylinder Non-condensing and uses Stuart Turners cylinders.
It mainly seem to be made of mild steel plate and bars for the base plates and the columns, the crank can either be machined from the solid or made up and pinned together,It also mentions pumps for the feed and lubrication.
Has anyone either made this engine or have the drawings for it as yet I can not seem to trace it anywhere
