I own a chiming mantle clock – I think it is a Smith Enfield movement, made about 1955.
Brass movement inside a wooden case. Presented to my father on his retirement. Label inside says "Repairs – E. Hitchcock and Son, Watchmakers, Market Place, Bingham."
8 day movement, two keys (one for chimes, hour and half hour, one for time).
It used to keep perfect time. Recently it started losing large amounts of time, even though the movement was still working.
The displayed time is adjusted by moving the minute hand. What seems to be happening is that the drive to the minute hand is through a slipping clutch – the minute hand is fitted to a long hollow cylinder, and the drive from the movement appears to be a shaft which is a sliding fit into the cylinder.
I would guess that the drive shaft should be a tight friction fit inside the minute hand cylinder. But now it is too loose, and the weight of the minute hand when pointing to 9 o'clock is enough to cause it to clip when it gets to this point.
Can anyone suggest a cure?
